embedded Visual C++ and C# in .Net
  • embedded Visual C++ and C# in .Net
    I know that I can take embedded Visual C++ code into a C# project for the compact framework in .Net but does anyone know if I can use C# code in my embedded Visual C++?
    You can use C# code in VC++ with the regular framework so I'd assume you would be able to with the compact framework but I have never tried.
    Installed.
    -GPSSecure- - GPS Tracking
      I am assuming the same thing but I am not sure if I will need to setup the C# as a project and bring it in that way or if I need to set it up another way.
