OS Problem
  • OS Problem
    Alright so i was finally able to install my OS after a few minor problems. Basically what i wanted to do what create 2 partitions. Partition C - 3GB for OS and install EWF and Minlogon. Partition 2 - 56 GB (rest of HD) and thats where i will put all of my stuff/applications. But when i created Partition 2 it formatted. Installed Windows XP Pro on Partition 1 (3g). Every time i restart the computer It asks me which Windows Xp Pro to load and there are 2. THe second one is fromn the 2nd partition. BUt i can partition and then formaton the send partition without it copying windows files to the partition. Is there any way i can erase that screen or create a partition without having the Windows INstall Setup copy files the my 2nd partition.
    Also, in order to fix this do i have to format my entire drive??
    2002 Mitsubishi Galant
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    Souund Blaster Audigy2 NX
    OPUS ITX PC Case
    How did you format the 2nd partition? Did you use the XP install CD to format?
      yeah i used the XP install CD. I actually was just reading on Microsofts website they told me to edit the boot.ini. So i did and now it works.....Thanks Enforcer
      Carputer Specs:
      Via M10K
      512mb Ram
      60GB HDD
      OPUS ITX PC Case
