Is there A DVD Player that shuts down video play back during driving
  • Is there A DVD Player that shuts down video play back during driving
    I live in California and you get a big fine, if you get cought watching a DVD on the front monitor. is there a way to send the dvd play back to the video out. I did it by extending my monitor but if the lcd is in the headrest, it would be hard because i cant see it.
    Via SP-1300, 512 MB, M1-ATX, 7" Liliput, DBT-120, 80 Gig 2.5" 5400 RPM HD, Ericsson T616, USB SB Live 5.1 sound card, XP Pro SP2, RoadRunner, Slim DVD -R/+R, XM Direct, and GPS/Map Monkey.
    Well if your got a Mini ITX board you can set the video to be displayed on the video out port.
    Mini ITX boards only let you have video play on 1 or the other source so it's either vga or composite/svideo
    But it doesn't sound like your got a mini itx.
    You can do this if you get a video card which does dual video you should be able to set only 1 source to display video instead of 2
    CarPC Status:
    GPS: 99%
    Hardware: 99%
    Software: 92%
    Case Install: 99.9%
    Dash Install: 100%
    Car Install: 72%
      Search for "Simple serial circuit" started by rando
      If you use this circuit with Frodo player, it will disable video playback if the parking/e-brake not engage.
      Y2K Accord Dell GX150
      EmoRebellion is a SCAMMER
