Turning a 17" monito into a 7" one
  • Turning a 17" monito into a 7" one
    I currently have my carputer in my house while i set set up the skin for iGuidance and i want to check to see how the skin will look on a 7" monitor. I want to make lots of changes so constantly going back and fourth to my car would be a reall pain. Is there any software or option in windows that will allow me to use my 17" monitor as though it were a 7" one. Maybe something were I input the physical size of my lilliput monitor and that is the only potion of the 17" screen it displays on.
    Thanks for the help!
    VNC into your carpc maybe
    PowerVoice v1 | NaviVoice Source
    GammaControl v2.4
    SKINbedder v3
    1995 Lexus SC300
      Or pcanywhere
      RexBruMet Skin for FrodoPlayer
      Nissan Aux-in MOD
      Originally posted by bgoodman
      We're an international forum, post in whatever langauge you like.
        Originally posted by thanatos106
        Or pcanywhere
        PCanywhere is a type of VNC
        Notice I didn't say which VNC to use
        GammaControl v2.4
        SKINbedder v3
        1995 Lexus SC300
          that is why I'm giving him the name of one..... so he can look better in limeware (just kiding)
          And to you:
          Nissan Aux-in MOD
            And to you:
            Free ones are ultravnc and some other one. Search the forums for ultravnc
            GammaControl v2.4
            SKINbedder v3
            1995 Lexus SC300
              that **** is to hard to setup...
              with PCanyware you just active the host enter the IP adress in the remote and that it (you can chat with the host..... and bla bla bla
              Nissan Aux-in MOD
                Resource hog?
                Anyways, we answered that guy's question probably
                Or he can just change the resolution on his monitor.
                GammaControl v2.4
                SKINbedder v3
                1995 Lexus SC300
                  I have used Real VNC in the past, I think i will use it for this... That is a clever Idea...thanks
                  Also changing the res wont get me the proper aspect ratio as my 7" is a widescreen
                    set the resolution you want and switch off stretching / hw expansion ?
                      XP's built-in Remote Desktop is way cooler then VNC.
                        What res. do you run the carputer monitor at? Just run your 17" at the same resolution that the lilliput runs at and be done with it. I run my Lilliput at 800x600, so for me all I would have to do is force my monitor to run at 800x600. You can do that at any resolution, let us know if you need help forcing it to display at the resolution you need it to.
                        Zen Fat Loss
                          Your everyday carpc geek and tech guru at your service. *bow*
                            Or better yet, install a frontend on your PC, such as Frodo or RoadRunner. Open it up and it will display on your desktop in a fairly close resolution to what your lilliput looks like. Open iGuidance and resize the window to the same as Frodo or RoadRunner. All you need to do is resize the iGuidance window to 800x480 (I think).
                              Real VNC is the best VNC alive. Oh did I mention that it is easy to set up and it's free?
                              Installed.
                              -GPSSecure- - GPS Tracking
