Nokia 6600 handsfree Help please
  • Nokia 6600 handsfree Help please
    Hi, I'm newbie and I need your help...
    I didnt' find any solution in the other posts so I've decided to post a new one.
    I'm trying to use the Nokia 6600 handsfree services with my pc using this USB Bluetooth. The connection seems established, because I see the handsfree local service connected and the Nokia handsfree audio gateway connected to the 6600
    If I try to call my 6600 from another phone I can see the call on my Pc but when I answer with the Pc I can't hear anything. It's the same thing when I try to listen an audio file from the Nokia to my pc. Can someone help me please?
    my widcomm drivers are
    4.0.1.700 of11/05/2004
    my 6600 firmware is
    V 5.27.0
    28-06-04
    NHL-10
    Thank you very much
    Chrysler 300C Touring 2006 CRD
    My ex car - Alfa 147 project
    Italian Rock Band! http://www.pikasso.it
    I can just talk for my Siemens S65 but I have to push the left button on my phone to hand the audio from the phone to the pc. maybe you have that option as well
    Lilliput 7" TS TFT, ASRock K7VM2, Duron 1,3 GHz, 512 MB DDR RAM, 30 GB Seagate HDD @ 5.400 rpm, WLAN w/ 500mW booster, Toshiba Slimline DVD-ROM Drive, D-Link USB Radio
    Download the German Voicepack 1.0 for FreeDrive now!
      Most likely you need a newer firmware version for your 6600 - that's what I ran into when trying to implement the bluetooth audio gateway stuff - from searching I read that Nokia's bluetooth implementation for the hands free stuff kind of sucked at first but was patched somewhat with the later firmware. At that point I said f it because I don't know anywhere local that can do the fw upgrade and I can't send my phone off for who knows how long to have it upgraded. Of course keep us informed if you find out anything new!
        I think you have the right, however I have wrote an email to Nokia support where I had explain the trouble. Now I'm waiting for an answer
          It's incredible, I asked at the Nokia Help online an they told me that they don't know this problem
            I've tryed to connect with the same usb dongle and the same widcomm drivers the nokia 6230 and 6310i( I think that the 6310i is older than 6600...)!! They work perfectly and the use they same bluetooth services(local and remote)!!!!!
            ....sorry for my english...
              My 6600 with latest firmware (5.53) not working! :-(
              Renault Megane II Berline 1.5 dCI Dynamique Plus 2004
              Epia SP13000, HDD 40 Gb, CarTFT MM400 7" touchscreen, SB Audigy 2 (PCI), Terratec Cinergy 600 TV/FM tuner, M1 ATX
              Gigabyte USB BT dongle, X-Micro Wlan USB stick
              Globalstar BR-353 USB GPS
                You should persist.
                I had got a 6600 too and I successfully connect it ti Pc via bluetooth with Trust BT dongle and WINDCOM drivers. But i remember had tried since day to make it working.
                I wonn't be able to remeber how I done because that makes a long time but you should try on several PC because sometimes there are uncompatibilities with the dongle.
                New prototype : 2DIN AUDI OEM-LIKE CARPC based on SYMPHONY II
                Motorized InDash Screen, Core 2 Duo 2.2Ghz, SSD
                Home Made In-Dash 7" Lilliput V1
                Home Made In-Dash 7" Lilliput V2 = LM-Lilliput Prototype
                First project in Peugeot 306
