FBI Anti-Piracy workaround?
  • FBI Anti-Piracy workaround?
    So I still haven't been able to find a successful work around for this Anti-Piracy BS that's on 4 of the last 7 CDs that I've RIGHTFULLY paid for....though I haven't spent much time working on it either....
    does anyone know of anything?
    Jan Bennett
    what cd's?
    肚子笑痛了
    S60 Install
      EAC doesn't work on them?
      '02 GTI
      [Routis '04] [Opus 90W] [160GB Maxtor HD]
      [Lilliput 7" TS] [VIA M10000] [XMPCR]
      [512MB RAM] [Custom housing]
      [Deluo GPS Mouse] [E-MU 0404 Soundcard]
      Progress Meter: [==============|] 99.9%
        Exact Audio Copy? The thing is I can't even see the music files on the cds!
        *sigh*
        jcdillin - I posted a thread about this twice but I didn't bother to search for the thread before posting this again, sorry...I'll see if I can find them and I'll link to them here....
        Jan Bennett
          judo - is LAME.exe the best engine? or do you recomend something else?
          Jan Bennett
            jchdillin:
            http://www.mp3car.com/vbulletin/showthread.php?t=50533
            http://www.mp3car.com/vbulletin/showthread.php?t=40476
            hope that helps!
            Jan Bennett
              Unhandled Exception
              at Translation.340 -> INDEX-RANGE
              I keep getting this error, fresh install and all.
              Before I go to try and rip a CD (that doesn't have the anti-piracy bs btw) I go in to edit the options. I change the naming scheme and it gives me the above error....any ideas?
              Jan Bennett
                ahhh, i've seen the light
                i've had this trouble before, let me see if I can find the program I used to do this.
                肚子笑痛了
                S60 Install
                  that would be sweet if you could!
                  Jan Bennett
                    I just use nero, set it to ignor errors. The errors are built in to make it not burn. I've burnt several windows disks like that.
                    2003 100th harley F-150
                    PCChips C3 VIA/eden, M1 ATX smart car.
                    Here is my project so far: My 100TH Harley-Puter
                    Ride safe
                    Buy my stuff: Stuff
                      right click on the drive in my computer and select the other session (audio or whatever), its most likely a multisession cd.
                      Alex
                      90 300zx twinturbo conversion
                      Epia C3, 512 ram, syntax mobo, 80 gig WD, Mediacar, GPS w/Routis, all behind drivers seat, 7in Lcd Lilliput VGA with Touch, wireless adapter for stumbling, Consult ODB1 adapter and data scanner.
                        Lame is indeed the best codec to use for mp3.... my personal settings are VBR at extreme quality ... any lower setting of quality and you start to lose the sonic nature of the lows yet VBR makes sure the file doesnt get too large.
                          what about alcohol 120%?
                            at one point there was a winamp3 plugin that ripped immediately, regardless of programming hiccups. I think it was made by Poikasoft, if I'm not mistaken. The only problem is, winamp has since taken that plugin off the site, although it's gotta be somewhere out there on the interweb.
                            Planning Meter I--->-I: 80%
                            Install Meter I-----I: 0%
                            Amount of stolen/bootlegged/DLed software: astronomical
                              these are my options:
                              AutoPlay
                              Play
                              Play with VLC media player
                              Search...
                              Open
                              Explore
                              _______
                              Sharing and Security...
                              Write these Files to CD
                              _______
                              Compress to ZIP + Options
                              _______
                              Scan for Viruses
                              _______
                              Eject
                              _______
                              copy
                              _______
                              Create Shortcut
                              _______
                              Properties
                              That's it!
                              Jan Bennett
