VB to Delphi Translation
  • VB to Delphi Translation
    I have this code in Visual Basic that I need to get working in Delphi. It is used to get SAPI to recognize words without having an XML file. I can't figure out why I can't get at least parts of the code to work in Delphi
    http://vbfrance.com/code.aspx?ID=16631
    My Current Code:
    Code:
    unit Unit1;
    interface
    uses
      Windows, Messages, SysUtils, Variants, Classes, Graphics, Controls, Forms,
      Dialogs, OleServer, SpeechLib_TLB;
    type
      TForm1 = class(TForm)
        SpSharedRecoContext: TSpSharedRecoContext;
        procedure FormCreate(Sender: TObject);
      private
        { Private declarations }
      public
        { Public declarations }
      end;
    var
      Form1: TForm1;
      Grammar: ISpeechRecoGrammar;
      PropertiesRule: ISpeechGrammarRule;
      ItemRule: ISpeechGrammarRule;
      TopLevelRule: ISpeechGrammarRule;
      //WithEvents RecoContext As SpSharedRecoContext;
    Const
      m_GrammarId = 10;
    implementation
    {$R *.dfm}
    // Emulate VB function IS NOTHING
    function IsNothing(Obj : OleVariant) : boolean;
    begin
      Result := IDispatch(Obj) = nil;
    end;
    // Emulate VB function VarX := Nothing
    function varNothing : IDispatch;
    var Retvar : IDispatch;
    begin
      Retvar := nil;
      Result := Retvar;
    end;
    procedure TForm1.FormCreate(Sender: TObject);
    var
      AfterCmdState: ISpeechGrammarRuleState;
      temp : OleVariant;
    begin
      SpSharedRecoContext.EventInterests := SREAllEvents;
      Grammar := SpSharedRecoContext.CreateGrammar(m_GrammarId);
      TopLevelRule := Grammar.Rules.Add('TopLevelRule', SRATopLevel Or SRADynamic, 1);
      PropertiesRule := Grammar.Rules.Add('PropertiesRule', SRADynamic, 2);
      ItemRule := Grammar.Rules.Add('ItemRule', SRADynamic, 3);
      AfterCmdState := TopLevelRule.AddState;
      TopLevelRule.InitialState.AddWordTransition(AfterCmdState, 'test', temp, temp, '****', 0, temp, temp);
      Grammar.Rules.Commit;
      Grammar.CmdSetRuleState('TopLevelRule', SGDSActive);
    end;
    end.
    Thanks in advance
    PowerVoice v1 | NaviVoice Source
    GammaControl v2.4
    SKINbedder v3
    1995 Lexus SC300
    You've made a number of mistakes in your parameters in the function call that raises the exception. Have a look at:
    http://www.mail-archive.com/delphi-e.../msg01264.html
    I took your code and adapted it with the parameters used in here, and it seems to execute (I haven't gone any further than checking that no exception is raised). I think the constant name of SPWT_LEXICAL used in the example may not be correct, but it maps to a valid value so it still works. The correct range of constants can be found in the type library file just below the SpeechGrammarWordType type statement (there are three constants).
    Good luck!
    Ric.
    EZSync - http://www.richmet.com/ezsync
      I haven't read the article, but this may be of help also:
      http://bdn.borland.com/article/0,1410,29583,00.html
        Good luck!
        Ric.
        Perfect!
        Guess the base of NaviVoice... look at the first screenshot of NV... its identical to that app
        GammaControl v2.4
        SKINbedder v3
        1995 Lexus SC300
          Code:
          unit Unit1;
          interface
          uses
            Dialogs, SpeechLib_TLB, OleServer, StdCtrls;
          type
              SpSharedRecoContext1: TSpSharedRecoContext;
              Button1: TButton;
              procedure SpSharedRecoContext1Hypothesis(ASender: TObject;
                StreamNumber: Integer; StreamPosition: OleVariant;
                const Result: ISpeechRecoResult);
              procedure Button1Click(Sender: TObject);
            private
            public
              procedure CreateGrammar;
              procedure AddWord(word: String);
            end;
          var
            Form1: TForm1;
            SRGrammar: ISpeechRecoGrammar;
            WordNumber: Integer;
            // Create this object and fill it with the words
            // or phrases you want to recognise before calling CreateGrammar
            Phrases: TStringList;
          implementation
          {$R *.dfm}
          procedure TForm1.SpSharedRecoContext1Hypothesis(ASender: TObject;
          var text: String; confidence: Integer;
          begin
          text:=Result.PhraseInfo.GetText(0,-1,True);
          Confidence:=Integer(Result.PhraseInfo.Rule.Confidence);
          showmessage(text);
          end;
          procedure TForm1.AddWord(word: String);
          Var Value: OleVariant;
          begin
            Inc(WordNumber);
            Value:=WordNumber;
            Rule.InitialState.AddWordTransition(Nil, word, ' ', SGLexical, 'value',1,value,1.0);
          end;
          procedure TForm1.CreateGrammar;
          var
          i : integer;
          begin
            //OnAudioLevel event is not fired by default - this changes that
            SpSharedRecoContext1.EventInterests := SREAllEvents;
            SRGrammar := SpSharedRecoContext1.CreateGrammar(0);
            Rule:=SRGrammar.Rules.Add('word',SRATopLevel+SRADefaultToActive,0);
            WordNumber:=0;
            for i := 0 to Phrases.Count-1 do begin
              AddWord(Phrases[i]);
            end;
            Rule:=Nil;
            SRGrammar.Rules.Commit;
            SRGrammar.CmdSetRuleIdState(0, SGDSActive);
          end;
          procedure TForm1.Button1Click(Sender: TObject);
          begin
          addword('test');
          end;
          end.
          It raises an exception when I click on the button
          GammaControl v2.4
          SKINbedder v3
          1995 Lexus SC300
            Originally posted by 0l33l
            Code:
            unit Unit1;
            interface
            uses
            type
                Button1: TButton;
              private
              public
              end;
            var
              Form1: TForm1;
            implementation
            {$R *.dfm}
            begin
            showmessage(text);
            end;
            begin
              Inc(WordNumber);
              Value:=WordNumber;
            end;
            var
            i : integer;
            begin
              WordNumber:=0;
              end;
              Rule:=Nil;
            end;
            begin
            addword('test');
            end;
            end.
            Don't you need to call 'CreateGrammar' ?
            Note I fiddled with this a bit more last night after posting, and the call to CmdSetRuleIdState was failing.
              Code:
              unit Unit1;
              interface
              uses
              type
                  Button1: TButton;
                private
                public
                end;
              var
                Form1: TForm1;
              implementation
              {$R *.dfm}
              begin
              showmessage(text);
              end;
              begin
                Inc(WordNumber);
                Value:=WordNumber;
                Rule.InitialState.AddWordTransition(Nil, word, ' ', SPWT_LEXICAL, 'value',1,value,1.0);
              end;
              var
              i : integer;
              begin
                WordNumber:=0;
                end;
                Rule:=Nil;
              end;
              begin
              addword('test');
              CreateGrammar;
              end;
              end.
              It fails when I press the button.
              Can you just post your source?
              GammaControl v2.4
              SKINbedder v3
              1995 Lexus SC300
                I have no source to post. I just fiddled around for a while then threw it away. What I was saying is it is bound to fail when you press the button because all you're doing in the button's event handler is calling 'addword'. You need to have called 'CreateGrammar' first. You previously had the code in the FormCreate but I don't see a FormCreate any more.
                  In addition to this, the code you've posted doesn't instantiate the 'Phrases' object, so you'll get an access violation inside CreateGrammar.
                    Code:
                    unit Unit1;
                    interface
                    uses
                    type
                        Button1: TButton;
                      private
                      public
                      end;
                    var
                      Form1: TForm1;
                    implementation
                    {$R *.dfm}
                    begin
                    showmessage(text);
                    end;
                    begin
                      Inc(WordNumber);
                      Value:=WordNumber;
                    end;
                    var
                    i : integer;
                    begin
                      WordNumber:=0;
                      end;
                      Rule:=Nil;
                    end;
                    begin
                    addword('test');
                    end;
                    begin
                    Phrases := TStringList.Create;
                    CreateGrammar;
                    end;
                    end.
                    Same thing... and I create the Phrases and call creategrammar. It fails when I press the button.
                    GammaControl v2.4
                    SKINbedder v3
                    1995 Lexus SC300
                      [code]Same thing... and I create the Phrases and call creategrammar. It fails when I press the button.
                      Are you getting the fail in the call to CmdSetRuleIdState I mentioned in post #6? It's an OLE error. If so, I'm as stuck as you are.
                      Ric.
                        Ric.
                        When mine fails its at Rule.InitialState.AddWordTransition(Nil, word, ' ', SPWT_LEXICAL, 'value',1,value,1.0);
                        GammaControl v2.4
                        SKINbedder v3
                        1995 Lexus SC300
                          You haven't said what the error is, but if it's an access violation then that's probably because of the line Rule:=nil in CreateGrammar. Take it out. AddWord uses Rule, and Rule will be nil by the time you press your button.
                          Really those global variables ought to be class variables so they can be tidied up with the form class on shutdown.
                            Code:
                            unit Unit1;
                            interface
                            uses
                            type
                                Button1: TButton;
                                Button2: TButton;
                                procedure Button2Click(Sender: TObject);
                              private
                              public
                              end;
                            var
                              Form1: TForm1;
                            implementation
                            {$R *.dfm}
                            begin
                            showmessage(text);
                            end;
                            begin
                              Inc(WordNumber);
                              Value:=WordNumber;
                            end;
                            var
                            i : integer;
                            begin
                              WordNumber:=0;
                              end;
                              //Rule:=Nil;
                            end;
                            begin
                            //addword('test');
                            end;
                            begin
                            Phrases.Add('testing');
                            Phrases.Add('hi');
                            CreateGrammar;
                            end;
                            procedure TForm1.Button2Click(Sender: TObject);
                            begin
                            //addword('hi');
                            end;
                            end.
                            Sweet! That works now
                            Now I just have to figure out how to suit it for my needs
                            Thanks ric355!
                            GammaControl v2.4
                            SKINbedder v3
                            1995 Lexus SC300
