A.I.M.E.E XM - **Release**
  • A.I.M.E.E XM - **Release**
    Yes!
    The A.I.M.E.E team have released something! (No sniggering in the back!)
    Following the release of FrodoXM Service yesterday, here is the first Beta of A.I.M.E.E XM.
    Code:
    Changelog
    A.I.M.E.E XM.exe  --  1.0.0.1
    -- Bug Fix: Skinned Signal Status
    -- New Features: Implemented services.dat file to speed up loading
    A.I.M.E.E XM.exe  --  1.0.0.0  --  Inital Release
    Download A.I.M.E.E XM Beta 2
    Code:
    A.I.M.E.E XM Beta 1
    Requirements:
    VB6 Runtimes
    FrodoXM Service must be installed, and XMClient.dll must be
    registered on your machine
    Configuration:
    aimeexm.ini is the main configuration file
    Contents of aimeexm.ini:
    [Appearance]
    FullScreen=               True/False
    WindowWidth=              If FullScreen=False, width of window (pixels)
    WindowHeight=             If FullScreen=False, height of window (pixels)
    WindowLeft=               If FullScreen=False, window left (pixels)
    WindowTop=                If FullScreen=False, window top (pixels)
    DaySkin=                  Directory name containing Day Skin
    NightSkin=                Directory name containing Day Skin
    DaySkinSwitchTime=        Hr:Min:Sec to switch to Day Skin
    NightSkinSwitchTime=      Hr:Min:Sec to switch to Day Skin
    AutoSwitchDayNightSkin=   True/False
    ShowMouseCursor=          True/False
    [XMRadio]
    FrodoXMServicePath=       Full Path\Filename of FrodoXMService.exe
    LastChannel=              Last channel listened to
    Preset1=                  First Preset
    Preset2=                  Second Preset
    Preset3=                  Third Preset
    [Services.dat]
    The services.dat file contains information on the available channels. Should the channel listing change dramatically, delete this file and A.I.M.E.E. XM will rebuild this file the next time it runs.
    Useage:
    Run A.I.M.E.E XM.exe
    A.I.M.E.E XM will tune last played channel
    It will then load all stations/details into listing - this may take a few seconds,
    depending on the number of channels and speed that it updates, this will take longer the first time when services.dat is deleted.
    Once this is done, channel listings will be available for scrolling
    Double-clicking on a channel, or clicking on "Tune" will tune the
    selected channel.
    You can also have three presets saved. Click on the Preset button to tune to that preset.
    To save presets, tune to the channel, and press/hold the Preset button for ~3 seconds - the display will then change to show that the Preset has been saved.
    Volume controls main volume. Volume increases/decreases by 1% intervals for 0-15% and by 5% intervals for 20-100%
    Mute is a toggle which controls the hardware Mute function within your XM hardware.
    Co-Developer of A.I.M.E.E
    www.aimee.cc
    nice! what is the window name so we can embed it?
    肚子笑痛了
    S60 Install
      Little Buggy, But works !
      [H]4 Life
      I'm a lesbian too.
      I am for hire!
        Bugs.
        1. List doesn't immediatley populate.
        2. Double Clicking List Changes channel properly, but the info jumps to channel 1.
        ---(Could be combo bug with my stuff, will check)
        3. There are like these funny little pink sliders or something out of place, looks like
        signal strength ?
        [H]4 Life
        I'm a lesbian too.
        I am for hire!
          Looks like window name for embedding is
          A.I.M.E.E - XM Radio
            Window name is A.I.M.E.E - XM Radio
            I'm looking at the bugs now.
            Garry
            www.aimee.cc
              Yeah the list does take a while to load
              肚子笑痛了
              S60 Install
                Here is a error I get upon embedding
                肚子笑痛了
                S60 Install
                  What are you embedding it into - i'll need to have a look.
                  Garry
                  www.aimee.cc
                    Garry
                    Centrafuse,
                    肚子笑痛了
                    S60 Install
                      Originally posted by frodobaggins
                      Bugs.
                      Confirmed to be bug in the service. Will fix and rerelease.
                      [H]4 Life
                      I'm a lesbian too.
                      I am for hire!
                        Service is re-released as Beta 3
                        Get it here: http://www.mp3car.com/vbulletin/showthread.php?t=56995
                        [H]4 Life
                        I'm a lesbian too.
                        I am for hire!
                          Re-released as Beta 2
                          Check first post for changelog/download link.
                          I'll look at embedding once I get home and have a half-decent net connection to download/install Centrafuse.
                          Garry
                          www.aimee.cc
                            I've found a bug with the signal strength.
                            Updated Beta 2 (re-download if you've already got it), and have also included the fonts required to view it properly
                            Garry
                            www.aimee.cc
                              Are there any SendMessage Codes? I need to be able to use a remote through Girder more than anything else.
