HTA XM Player (using FrodoXMService)...
  • HTA XM Player (using FrodoXMService)...
    HTA == HTML Application
    As some of you know I've been playing around with Mozilla Application development using XUL. It's really powerful and cool, but I wanted to try out the same idea in IE. HTA's are basically HTML pages, with a *.hta extension instead of *.htm. You run them just like any other EXE, just double-click. They run in a full-rights IE shell. Anyways, this was simply a proof of concept. It's not meant to look pretty (both code-wise and UI). You need FrodoXMService installed obviously. I use an XML "data island" and XSLT for the channel list to make sorting easier and faster (you can click on the column names to sort). XUL has much better UI elements than your basic HTML which is what you have to use for HTA's so I had to hack a scrolling list box. It works, so whatever...
    So anyways, HTA's are pretty cool because you've got full support for everything in Windows. XUL is a lot better for UI work, but it's limited to mostly XPCOM for components which is not as "easy" to write for as .NET or COM. There's an ActiveX plugin for Mozilla/Firefox but it doesn't support events in XUL mode (in HTML mode it does) so I can't use FrodoXMService client in XUL. However, I've written a rough XUL client using JavaXM. It's pretty cool, I can load local Java libraries with JavaScript in XUL and run them no problem. But there also, it's limited due to how JavaXM was written (it sends events to objects that implement a certain interface, but you can't implement java interfaces in Javascript). I had started writing my own XPCOM XM class, but I didn't feel like finishing it. So potentially if I really wanted to use XUL I would have to make an XPCOM class for XM. Anyhow, I'm not sure why I'm so fascinated with all this XML/Javascript stuff...but it's fun.
    NOTICE: since I can't upload an HTA file, I've uploaded the app as a .txt. Just rename it to .hta after you save it...
    PS - one of the really nice things of using HTML/XUL is how easy and powerful skinning becomes since you can take advantage of the ultimate skinning tool: CSS!! In this example I just use inline styles in the elements, but in a "real" app I would just use a stylesheet file so you can just swap different stylesheets and have full control over the display of the whole UI.
    *UPDATE*: made a few minor UI changes, cleaned up CSS code...
    EWF, HORM, MinLogon on XP.
    Zotac ION Atom N330, 2GB low-profile RAM, M3-ATX
    Win Embedded Std 2011 RC
    OCZ Vertex Turbo 30GB SSD
    Lilliput 629 Transflective, WRX Screen Mount
    BlueSoleil BT, i-Blue GM-2 GPS, DirectedHD Radio, Andrea Mic
    VoomPC 2
    Excellent !
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
      cool, i will check it out
      VIA EPIA M1000
      Casetronic C134
      512MB, 40G Hard Drive, 8x DVD-ROM
      Xenarc 700TS ULTRABRIGHT
      Griffin Powermate
      Jeff Bipes AUX-IN for Audi's
      Opus 150W
      WinXP sp2
      myHTPC, VoiceMate Pro
      Street Atlas 2001
        really nice work. I was working on something in vb.net using frodo's service but i have kind of put it on hold for the moment.
        VIA EPIA M1000
        Casetronic C134
        Griffin Powermate
        Opus 150W
        WinXP sp2
        Street Atlas 2001
          sweet! very cool idea
          My Install
          Software:
          CFiG v1
          iGuidance Plugin for CF
          CarShell
          Working shell for a CarPC
          StopWatch
          StopWatch plugin remade for centrafuse RC1
            thanks. btw, HTA's are also what XP MediaCenter uses for its apps.
            VoomPC 2
