Multiple Video cards on one pc
  • Multiple Video cards on one pc
    does anyone know of a similar software to this
    http://www.thinsoftinc.com/products_betwin_info.html
    it allows multiple video cards/users to access the same pc as if it were 2 or 3 separate pcs
    ive emailed faxed and tried calling them but i havent heard a word.
    as a new customer almost always when this is the case you can exspect bad customer service down the line should something arise so i hoping someone knows of an alternative
    thanks
    .______
    | '_ |__\___
    [(o)|___(o)] XB
    ._________
    | I__I I_I|_\__I
    [(o)______(o)]b VanPimpin'
    LostReceptions Apps D/L Here
    GPSGasoline- Rewriting
    CarPCNetwork
    all it does is let each user access the desktop of each video card it sets it so 1 usb mouse and keyboard work on that desktop then it's pretty simple.
    What exactly do you want to do?
    CarPC Status:
    GPS: 99%
    Hardware: 99%
    Software: 92%
    Case Install: 99.9%
    Dash Install: 100%
    Car Install: 72%
      Iremember when I was using red hat linux with my dual monitor setup, I had the option to assign a keyboard and mouse to each card (or head) ... so I know linux could do it but chances are you want XP based..
      Shawn
      Check out my web company Minneapolis Web Designer | MODx Web Design - Himmelberger Design
        im looking to have dedicated gps on one screen with its own separate TS<mouse> and kb and rr running on the other also with a TS
        .______
        | '_ |__\___
        [(o)|___(o)] XB
        ._________
        | I__I I_I|_\__I
        CarPCNetwork
          ohh so just TS on both .. .. well no problem. just can't use the TS at the same time .. like 2 simultaneous touches.. or so I think..
          Shawn
            no no basically
            display 1 rr with everything except gps on it
            display 2 gps (iguidance) only
            i cant do extended desktop cause theres no way to configure it that way (as far as i know)
            .______
            | '_ |__\___
            [(o)|___(o)] XB
            ._________
            | I__I I_I|_\__I
            CarPCNetwork
              anyone familiar with this could it be done with 2 different software configs for 2 different types of TS's?
              .______
              | '_ |__\___
              [(o)|___(o)] XB
              ._________
              | I__I I_I|_\__I
              CarPCNetwork
                wish I had the realestate for screens that you do then i could try it out...
                I would check with turbocad, he might have some insite on this...
                have you decided on your screen setup?
                My Install
                Software:
                CFiG v1
                iGuidance Plugin for CF
                CarShell
                Working shell for a CarPC
                StopWatch
                StopWatch plugin remade for centrafuse RC1
                  look into ultramon it will do what u want
                  CarPC Status:
                  GPS: 99%
                  Hardware: 99%
                  Software: 92%
                  Case Install: 99.9%
                  Dash Install: 100%
                  Car Install: 72%
                    i got a 10.4 on its way and im gonna have 2 xenarcs at the base unfortunatly doesnt look like itll be anywhere near done by the meet
                    .______
                    | '_ |__\___
                    [(o)|___(o)] XB
                    ._________
                    | I__I I_I|_\__I
                    CarPCNetwork
                      im abit confused now your got 3 screens?
                      you can use both touchscreens on seperate screens there is a setting to set the mouse to only go to the edge of one desktop then use the other to only go to the edge of the second screen.
                      Use ultramon to force an app to loadup in a set position so you can have RR playing in the main screen then the GPS in the other screen.
                      This is what you want?
                      CarPC Status:
                      GPS: 99%
                      Hardware: 99%
                      Software: 92%
                      Case Install: 99.9%
                      Dash Install: 100%
                      Car Install: 72%
                        thanks
                        I am pretty sure that the program Multiplicity from the software company Stardock will do what you are looking for.
                        Intel P4 2.0 Gigahertz
                        512 Megs Of Ram
                        Western Digital 60 Gig Hardrive
                        DVD/CD-RW Combo Drive
                        Coleman Powermate 400/800 Inverter
                        Custom Case
