One-Click WebCam Recording!
  • One-Click WebCam Recording!
    If you visit this thread for the first time, here is all you need: Capture!.zip
    Last night coded my first tool in C#.Net.
    There it is: Capture! - small WebCam tool specially for the Touchscreen
    (Probably you have to register to download the file. Sorry, mp3car.com has a file-size limit!)
    You need .NET 1.1. Check out the config.ini for all the parameters.
    Greetz! Chris
    Got any feature list or screenshots?
      Well, there are screenshots in the the linked thread. Unfortunately you can just see them when you're registered at the forum.
      @Prefect:
      I suggest you attach some screenshots in this forum too.
        Looks good.
          Ok, for us lazy people who don't want to translate the page what's it say? Where's the link to the proggie?
            Cause I was really curious, I joined the car-pc.info website, and then used http://www.freetranslation.com/ to translate from German to English to see what I had just signed up to
            Here's the English translation of the post, and the software screen shot
            Quote"
            Finally I have exactly that what I wanted. But one must make it always first itself!
            The DirectX. Capture Class Library being based on made I a Progrämmchen that my demands on a WebCam Recording tool fulfills for the Webcam in the car.
            I wanted a tool which Webcam-video with only a keystroke (or optionally also without) receives during the trip.
            Possible that makes above all a preconfiguring of all parameters to the Capture-Device and the video compressor per config. ini. In addition a file name is forgiven automatically, being based on a time stamp.
            So a single Button passes to start around the reception! Also many receptions can be made as desired after each other.
            The software indicates already received became now, wieviele seconds, would file is like largely that momentarily, how much place is yet available on the Harddisk and yet further could receive like long one with the current data rate.
            The reception stops automatically if only 50 MB freely are on the Harddisk.
            It can be configured, would file begun will should after wievielen MB a new. Per Default, a new reception begins after 200MB.
            The program can be served per Touchscreen or also only with the "Enter"-Taste.
            In the Idle-mode, one sees screen abundance the picture of the Webcam. In the reception mode a background picture as well as the status information. This schohnt the Prozessorpower of the little via C3
            All attitudes to the VideoCaptureDevice (Cam, solution, frame rate, video compression) and to the Audio Device (Soundeingang, Sampelrate, stereo/Mono, Audiokompression) can be undertaken direct in the program. The parameters should be transmitted then by hand into the config. ini.
            One reaches the attitudes to the video compression under "option - Property page - video Compressor..." DivX proved itself with me, as a precaution on the "fastest" attitude.
            In the config. ini can be indicated moreover, in which window-mode the program is supposed to be started. "Maximized" is good for the single business, the options "C FLATS" can be used, if Capture! out of C FLAT started becomes.
            Well known bugs: all error messages are not intercepted. For example in incorrect config. ini values, in not available CaptureDevices etc. occasionally overlap with the windows-Taskleiste. Rarely videos not correctly are recorded (Size remains in 0.00MB). In the maximized attitudes, one does not see the first text line in C
            FLAT entirely.. ..
            Bugs naturally can be reported me, it exists however no guarantee that I will be concerned therefore
            Someone should have established interest in the further development or at the Bugfixing, I will not forbid in that the source code.
            Nevertheless it pleases me even very especially that 1st the Progrämmchen somewhat dependably runs (my first C#. NET tool generally!) and 2 can receive. I now finally videos during the trip quickly and simply. Would be prettier wait natural the integration in C FLAT or cPos, but on that I now already a year.. (not badly meant)
            Greetings! Chris
            UPDATE: new version: for C FLAT, the config. ini in the C FLATS file must be copied now no longer.
            The program can be multiple on the PC available, with respectively other attitudes of the config. ini.
            For example: C:\Programme\Capture! Front --> front camera C:\Programme\Capture! Back --> stern camera C:\Programme\Capture! Supervise --> attitudes on 1 frame per second, front camera, strong compression, all 50MB a new would file = automatic and continuous
            supervision etc. "end Quote
            Here's the screen shot
            The file is 212kb (just over the limit allowed), but once you register on the car-pc.info website you can download the file.
            I plan on trying it out later today.
            GRod
            Carputer/AV System ~95% complete
            Parts all acquired - testing underway
            Fabrication and integration underway
            More on my Ride
              does somebody have it without registering?
              CAR:2001 Ford Crown Victoria
              PC: Acer EEE 900HA with Win7 with CF 2.0.
              Memory:1G
              Drives:160gig
              WI-FI:Cingular
              GPS:IG2k9
              Screen:Xenarc 700TSV
              The Florida Meets Thread
                Shame it needs DotNet
                  Haha sorry for posting only the link to the car-pc.info forum.
                  Here is the tool hosted on my server: Capture!.Zip
                  I don't think the automatic translation was a good idea "C FLATS"?? That should be "CES"
                  So here is a brief description in my own words:
                  this tool enables you to record videos with a single klick from your webcam. i can be configured via a config.ini, so you don't need to use a mouse to set up the capture devices and compression-filters before recording. it is designed to need as less input as possible to do his job. video files are named and saved automatically.
                  check out the config.ini for setting the capture device id and the save-to path for the videos.
                  per default the tool generates a new file after 200mb of recording.
                  set "WindowStateOnLoad = maximized" for fullscreen view (disable windows-taskbar!)
                  Why is .Net bad?? It needs .Net because its written in C# and the DirectX.Capture Class needs .Net too. You can use Mono if you don't like MS
                  Something cool i recorded today: Capture_Zeitraffer_x25_25fps_wm9.avi (right-klick, Save target as... !)
                  Greetz! Chris
                    Not Found
                    The requested URL /public/capture.zip was not found on this server.
                    Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request.
                    [H]4 Life
                    I'm a lesbian too.
                    I am for hire!
                      Here is the Tool hosted on my server: Capture!.Zip
                      Link doesn't work.
                      Best thing to do is make a .rar and split it in two parts. (so you can post it here in the forum).
                      Thanatos.
                      RexBruMet Skin for FrodoPlayer
                      Nissan Aux-in MOD
                      Originally posted by bgoodman
                      We're an international forum, post in whatever langauge you like.
                        now the link is working...
                        i'm not gonna make split archives of a 212kb file
                        200kb limit....
                          What??? you can just split it in half
                          Or post a working link
                          Whatever man, I just DL you video file and it looks quite nice.
                          Thanatos.
                          BTW I know that the link is up know.
                          Nissan Aux-in MOD
                            Funny how some things translate - but sure beat getting out the German to English dictionary
                            I split the file into two RAR folders as suggested above, so here they are. (I would suggest extracting them to the same folder and then run it form there).
                            GRod
                            More on my Ride
                              GRod
                              Thank you very much Mr, you are a gentlemen
                              Thanatos.
                              Nissan Aux-in MOD
