road runner
  • road runner
    what would cause this problem?
    when i load RR and then play music and go back to the main screen all the buttons are non functional . you can press them and they appear to be pressed but nothing happens .I have to ctrl alt del and end task to shut it down.
    Well, I had this problem once it was caused from using Relative Path filename locatiosn in the RR config file for the SKIN. When I used absolute path, it works fine, like "C:\RR\...."
    Mark
    Website: http://www.greenpowerenthusiast.com/
    Car'Puter Project
    - Xenarc 700TSV
    - MSI RS482M-IL Mobo + AMD Turion MT-32 (25W)
    - 1x 256MB Corsair XMMS DDR400
    - M2-ATX
    - Belkin 802.11G W-Nic
    - Garmin 15H GPS
    - WinXP SP2 (NLited)
      you have to update your flash, see here
      http://www.mp3car.com/vbulletin/showthread.php?t=45529
        yea thanks that was it . i need to update my flash
