I need to close a program before going into hibernation
  • I need to close a program before going into hibernation
    Is there any way to close IGuidance (or any open app) before going into hibernation? If it's left open, my computer dumps memory when it resumes. I'm using frodoplayer as my FrontEnd. Is there a script or some XP utility that will do that?
    a. paired with this tool:
    http://www.mp3car.com/vbulletin/showthread.php?t=58933
    the process program from here: http://www.beyondlogic.org/solutions...rocessutil.htm
    should do the trick. Just say something like this:
    Code:
    C:\>process -k notepad.exe
    Command Line Process Viewer/Killer/Suspender for Windows NT/2000/XP V2.03
    Copyright(C) 2002-2003 [email protected]
    Killing PID 2792 'notepad.exe'
    Killing PID 4888 'notepad.exe'
    C:\>
    (except using iguidance.exe rather than notepad.exe of course) and that should work. But ive never used the first app before so I couldnt tell you if it does what you want.
    B. You should come to the minnesota meets .
    http://www.mp3car.com/vbulletin/showthread.php?t=55404
    Current projects: iGmod reloaded (Latest release) (put on hiatus indefinatly)
    Unlimited Internet and gps tracking for $6 a month with boost mobile!
    Carputer 2: www.lmaocar.com
      Cool, I'll try that.
      I was planing on coming to the last one, but i didn't see the post til the last second
        Is it the app being left open or the GPS causing the dump? You should make sure you have the latest drivers for it. XPort may eliminate the problem too.
