help with c++ - trying to execute a bat
  • help with c++ - trying to execute a bat
    I wrote a small C++ app that first runs a batch script then rewrites that same batch script to include a new date
    The date part is fine and works but the batch script refuses to run and I get no errors
    Source
    Code:
    #include <iostream>
    #include <fstream>
    #include <Windows.h>
    #include <stdio.h>
    #include <cstdlib>
    using namespace std;
    int main()
    	SYSTEMTIME st;
    	GetSystemTime(&st);
    	ofstream outputFile("sync.bat");
    	int test = system("sync.bat");
    	if( test == -1)
    	{   cout << "Cannot execute command"; exit(1); }
    	outputFile << "ROBOCOPY \"G:\\Music\\Full Albums\" J:\\Music /S /Z /MAXAGE:";
    	outputFile << st.wYear;
    	if(st.wMonth < 10)
    		outputFile << 0;
    	outputFile << st.wMonth;
    	if(st.wDay < 10)
    		outputFile << 0;
    	outputFile << st.wDay;
    	outputFile << " /W:300";
    	outputFile.close();
    	return 0;
    sync.bat
    Code:
    ROBOCOPY "G:\Music\Full Albums" J:\Music /S /Z /MAXAGE:20050910 /W:300
    What am i doing wrong here?
    2004 G35 Coupe project
    When you say refuses to run I assume you mean that the system command always returns -1 right? If so try moving the 'ofstream outputFile("sync.bat");' line some time after the system(... command. That may be opening the file for writing and not giving you access to write it.
    EDIT: On the last line I meant give you access to execute it not write it.
    Installed.
    -GPSSecure- - GPS Tracking
      Moved ofstrem below the system() and it worked
      Thanks!
        No problem
        Installed.
          quick edit, brady.
          Installed
          Asus A7N8X-VM - AMD Mobile Athlon 2400
          512 Ram - 60GB HD - Opus 150w
          Lilliput 7" - Rikaline 6010
          [00000000000001100010-] 98% Completed
          Check Out My Install!!!
            Originally posted by Quattro
            quick edit, brady.
            I don't know what you're talking about
            Installed.
              Do you know how I would shift the time down from UTC to Pacific time? It says its the 13th right now and thats screwing things up
                Its a difference of 7 hours from UTC and pacific, so if you can compare your time with the UTC it would be easy. So if is still before 07:00 just subtract 1 from the day.
                Installed
                  Doh! That was too easy, thanks
                  Fiinished source if anyone cares
                  Code:
                  #include <iostream>
                  #include <fstream>
                  #include <stdio.h>
                  #include <cstdlib>
                  int main()
                  	SYSTEMTIME st;
                  	GetSystemTime(&st);
                  	if( test == -1)
                  	if(st.wHour < 7)
                  		st.wDay -= 1;
                  	if(st.wMonth < 10)
                  		outputFile << 0;
                  	if(st.wDay < 10)
                  		outputFile << 0;
                  	outputFile.close();
                  	return 0;
                    GetSystemTime() will give you UTC
                    GetLocalTime() will give you local or whatever yours is.
