Front end chooser ? anyone ?
  • Front end chooser ? anyone ?
    Hi
    I am not sure if this has been an idea before
    but what about a front end chooser ?
    an exe that replaces explorer.exe as the shell
    this app then has a few customisable buttons on it
    frodo nmc
    rr phonecontrol
    winamp explorer.exe
    centrafuse car amp
    media engine obd
    so that you can then choose the front end you want, of course if there is no selection, then perhaps a default is done automatically, there may be some times you want to use the pc but not through the front end, and to wiat for the front end to open up and then close
    what about it ?
    Nano ITX / 512 MB / 60 GB / Panasonic slot load / M1-ATX / Bu303 / Sound blaster 24 / PPi amps / rockford sub
    I would use that if someone made it...
    1990 Jeep Cherokee
    2000 VW Golf TDI 4dr
    2005 VW GTI MKIV - SOLD
      I wrote an app that does something similiar to this. Basically because I/we all enable our front ends as the shell sometimes this can limit our abilities to access certian features of our PC's. In my hardware design my front end is stored on an external 2.5" drive. Forseeing myself forgetting to put in the 2.5" drive ocasionally, causing the system to boot with no front end, I devised a plan.
      My plan was to have a CF card (in the MII's CF slot) with my frontend on it. The OS on a CF card connected to IDE and a 2.5" External drive capable of mass storage, with my front end on it.
      The shell I designed is actually the new windows shell. When loaded it figures out if the primary front end is available (on the 2.5" drive) If its not then looks for the secondary front end (located on the CF card) If thats not available, then is loads explorer.exe... If thats not available it will try to load a "launch file window" (for diagnostics)
      The app has an editable XML file where you can chose (Primary,Secondary,Emergency) applications. Also one addition, is that it watches the primary and secondary applications for termination (a crash) if the app crashed, it relaunches it within 5 seconds. Like windows will do to its shell.
      I can post some base code OR possibly re-design the app to how you guys want it... Of course I'll do this only if there's enough interest. But when I get home I will at least post the basecode.
      Progress [I will seriously never be done!]
      Via EPIA MII
      512MB RAM
      OEM GPS (embedded)
      nLite WinXP pro on
      1GB Extreme III CF card
      Carnetix 1260 startup/ DC-DC regulator
      Software: Still, re-Writing my existing front end in .Net
        Yip, this is getting on to the right track
          Someone could easily edit the code to do what you guys wanted. Its all based of XML for one thing so that would really make it easier.
          Via EPIA MII
          512MB RAM
          OEM GPS (embedded)
          nLite WinXP pro on
            what about this? http://www.mp3car.com/vbulletin/show...light=carshell
            altho intellas idea is purdy cool!
            Roy
            2005 Range Rover 4.4
              Code:
                 Private primary_directory As String
                  Private secondary_directory As String
                  Private emergency_directory As String
                  Public Enum ENUM_ShellState
                      primary
                      secondary
                      cleared
                      emergency
                  End Enum
                  Private ShellState As ENUM_ShellState
              Private Sub frm_main_Load(ByVal sender As Object, ByVal e As System.EventArgs) Handles MyBase.Load
                      Dim node_data As String
                      Dim settings As New XmlDocument
                      Dim node As XmlNode
                      If File.Exists("settings.xml") Then
                          settings.Load("settings.xml")
                          Dim primary_app As XmlNodeList
                          primary_app = settings.GetElementsByTagName("application")
                          Dim p_nodes As XmlNode
                          For Each p_nodes In primary_app
                              node_data = p_nodes.ChildNodes(0).ChildNodes(0).Value
                              Select Case (p_nodes.ChildNodes(1).ChildNodes(0).Value)
                                  Case "1"
                                      primary_directory = node_data
                                  Case "2"
                                      secondary_directory = node_data
                                  Case "3"
                                      emergency_directory = node_data
                              End Select
                          Next
                          Call launch_something()
                      Else
                          lbl_status.Text = "settings.XML missing"
                      End If
                  End Sub
                 Private Sub launch_something()
                      Dim filename As String
                      Try
                          Shell(primary_directory)
                          ShellState = ENUM_ShellState.primary
                      Catch ex As Exception
                          ShellState = ENUM_ShellState.cleared
                          Try
                              Shell(secondary_directory)
                              ShellState = ENUM_ShellState.secondary
                          Catch ex2 As Exception
                              Try
                                  Shell(emergency_directory)
                                  ShellState = ENUM_ShellState.emergency
                                  lbl_status.Text = "Emergency mode!"
                                  process.Enabled = False
                              Catch ex3 As Exception
                                  'diag_emergency.ShowDialog()
                                  FileExp.Filter = "Exec (*.exe)|*.exe|" & "All files|*.*"
                                  If FileExp.ShowDialog() = DialogResult.OK Then
                                      'showDialog method makes the dialog box visible at run time
                                      FileName = FileExp.FileName
                                  End If
                                  If Not filename = "" Then
                                      Try
                                          Shell(filename)
                                      Catch ex4 As Exception
                                          launch_something()
                                      End Try
                                  Else
                                      launch_something()
                                  End If
                                  lbl_status.Text = "Catastrophic Failure!"
                              End Try
                          End Try
                      End Try
                  End Sub
                Private Sub process_Tick(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles process.Tick
                      Dim Proc As Process
                      If Not ShellState = ENUM_ShellState.cleared Then
                          Try
                              Proc = System.Diagnostics.Process.GetProcessesByName("Carinterface")(0)
                              launch_something()
                          End Try
                      End If
                  End Sub
              Via EPIA MII
              512MB RAM
              OEM GPS (embedded)
              nLite WinXP pro on
                How to use it:
                Below is the XML file. In directory tag you put the applications shell path
                The priority is self explanitory.
                The name tag is for the process name, so launch your app press ctrl + alt + delete and look for the exe of your front end and put that here.
                Oh and don't try Explorer.exe if its already as your windows shell, it freaks the machine out... not sure why...
                Code:
                <settings>
                	<application>
                		<directory>C:\carinterface.exe</directory>
                		<priority>1</priority>
                		<name>CarInterface</name>
                	</application>
                	<application>
                		<directory>E:\</directory>
                		<priority>2</priority>
                	</application>
                	<application>
                		<directory>C:\</directory>
                		<priority>3</priority>
                		<name>Emercency</name>
                	</application>
                </settings>
                Via EPIA MII
                512MB RAM
                OEM GPS (embedded)
                nLite WinXP pro on
                  So does this work? Anyone else tried it?
                  VoomPC, VIA C7 1.5 Ghz, 7" Newision LCD, 80 Gig WD 5400 RPM Laptop Drive, M2-ATX, RoadRunner, iGuidance, Freedom 2.0, AT&T Natural Voice Hot Babe Audrey. All wrapped up in a piece of crap Suzuki Grand Vitara.
