Road Runner, Routis (GPS), Winamp
  • Road Runner, Routis (GPS), Winamp
    Ok I got one of those voompc's
    I also have Deluo Routis running
    Software:
    Bluetooth PCMCIA (working)
    phonecontroller.net
    Deluo Routis (GPS)
    Winamp (whatever the latest one is)
    Ok well my problem is getting Routis to load up in Road Runner.
    I installed it.. pointed the settings to the folder.
    and gave the window name both as the "Routis" or the class name with the ! (don't have it here)
    GPS doesn't load.. or even embed it. or anything?
    anybody have any help on this..
    also i think the other settings are a bit messed up..
    Finally I heard that I can play ipod music just by plugging in my ipod..
    I think it said to add it as a drive.. and roadrunner would figure out the itunesDB but it didn't work for me.
    Thanks again everyone.. I appreciate it ,,
    also I 'm using an audi sking I think it's called LS are there others? Navigation is quite important to me
    thanks in advance
    p.s. i did do quite a bit of searching
    dGV
    Search for RoutisLauncher, or Kill Routis warning windows.
    The reason it is not embeded is because of that warning windows and you have to push OK button to close it. Read the search result will tell you what to do.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
      Still nothing
      I don't think my Road Runner listens to anything I do
      I tried the routis Launcher and RoutisHandler
      i don't think it even bothers to open routis.. there is no sign that it even attempts it in taskmanager..
      any help would be greatly appreciated.
      I also bought destinator.. that might work better but not sure how to set it up
      dGV
        What Road Runner skin are you using?
        Does Routis Launcher/handler launch and close the warning window for you? If it does the program does it job. Now the problem you have is the skin file. Some skinner hardcode the path and window name in the button. You have to modify it accordingly. I do use Routis and has no problem.
          the skin
          no actually I don't think it opens routis at all..
          I openned up routis it works fine.. and I've used the routis launcher i found on the website..
          the skin is ls3.0 B4 and all i modified was the audi symbol in the middle (sort of like this skin )
          any ideas...
          Thanks,
          dGV
            any ideas...
            Thanks,
            dGV
            LS3.0 uses iGuidance for GPS.
            You have to edit the *.skin file to change any reference from iGuidance to Routis.
              ugh..
              hmm
              I have no clue then.. i couldn't find references to iguidance doing a search int he files using windows..
              are htere any other skins that handle routis ? might just be easier to swap
              dGV
                ugh....
                ok I borrowed iguidance from a friend to see if i could get it to work before buying..
                I still can't get it with LS skin to work nothing shows up in the window..
                i've try IGmod 3 to help..
                argh.. maybe none of this works iwth road runner? what skin could i use.. this is nuts
                dGV
