Problem with directshow filter and WMP
  • Problem with directshow filter and WMP
    I have the directshow filter installed for .ape files installed and WMP will play .ape files...after a fashion. The problem I have is that is will not play the files when I first open them. If I double click the files in file explorer (which are associated with Windows Media Player), WMP will open and imediatly give an error that it can't play the file. If I click OK on the dialog and then click the play button it will think for a second and play the file.
    I have two machines. One is setup fine for .ape and WMP plays w/o errors. The machine with the problem is a fresh install of XP home.
    Also note that the machine acts the same way if I am in WMP and I choose File->Open and open a file of .ape. The error shows.
    Anyone have anything they can suggest? I need to fix this problem. Thanks in advance for any advice you can offer.
    I am going to use Frodo player as my front end and it won't play my .ape files until I solve this problem. grr.
    My Work Thread:
    http://www.mp3car.com/vbulletin/showthread.php?t=72552
    Source switcher for Lill
    http://www.mp3car.com/vbulletin/show...d=1#post841007
