New RR Image Viewer
  • New RR Image Viewer
    Road Runner haven't an image viewer, so I developed a new program called ImageViewer.
    Fully customizable and skinnable by a INI file.
    To embed in RR: "LOAD;YOURSKIN.skin;ImageViewer;C:\INSTALLATIONPAT H\ImageViewer.exe;ImageViewer"
    Try it!!! For any request may mail is [email protected]
    Bye!!!
    You should post in RR forum.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
      could someone move this post?
        ci pensa un moderatore
        My car install
          Looks great. Some key shortcuts so we can use RR's buttons to send commands in would be nice.
          iGMon - Integration between iGuidance and Road Runner
          CFX - Skin for Road Runner
            stay tuned, i'm working on it!!!
              ok, update done.
              ESC -> Exit program
              P -> Previous
              N -> Next
              B -> Browse
              S -> Slideshow ON / OFF
              L -> Select Item
              UP and DOWN to change item in listbox.
              Do you like it? Please let me know!!!
              Bye
                Better also assigning other two letters of Key shorcut to the buttons UP & Down ,good work this!
                Mauri
                  in RR you can use SENDKEY;{UP} and SENDKEY;{DOWN}
                    Nice work for RR. But from my size three remarks.
                    1. Some problem with scale (see picture). I think, You scale picture on start, than it rescale by RR, and I see white bars on right and bottom.
                    2. Then I write ImageViewer.ini, and RR start, he is embbeded MS Explorer . Can You make another name window, for ex. ImageViewerForRR ?
                    3. Can You make in Ini-file key with distance beetwen string in broweser window? In this version not easy click on touchscreen by finger. Font size smaller, then finger I can make a big font size, but this is not buateful .
                      And
                      4. Scrolbar has a Window skin Can You make it by RR style?
                      For information, my config
                      Main_X = 0
                      Main_Y = 0
                      Main_Width = 920
                      Main_Heigth = 550
                      Filelist_X = 10
                      Filelist_Y = 10
                      Filelist_Width = 905
                      Filelist_Heigth = 475
                      and filed for embbeded in skin
                      A01,5,54,905,475,000
                        First test of embedding
                        Screenshots of Browse and Image view with my skin.
                        Mauri
                          1. Your problem is background: ImageViewer doesn't shrink to fit image, you have to create a good resized background.
                          2. Nice idea, i'm doing it.
                          3. I can't. The object Listbox doesn't make you set the distance between string.
                          4. It could be. I will check it out.
                          Bye.
                          @ Mauri: NICE JOB!!!
                            Mauri
                            Any chance of posting your skin for the Image Viewer?
                              Bye.
                              1. Background has resolution 1000/550, that rather, than dimension in INI.
                              3. May be a blank row?
