How to properly (and easily) hack using ResHacker.
  • How to properly (and easily) hack using ResHacker.
    So I hear that many of you are going through pains attempting to modify iGuidance using ResHacker. Here is the proper way to do it.
    You will need:
    1) Resource Hacker 3.4.0 This is a Windows Resource Editor, which gives you access to modify dialogs, bitmaps, icons, etc. for some application files.
    2) GoRC: This is a freeware resource compiler. It will turn a .RC file into a .RES file.
    Summary of procedure: Export .RC from Reshacker, modify resources, compile a .RES file from the .RC, and import .RES file using Reshacker.
    Let's assume you want to modify all the bitmaps for iGuidance.
    Procedure:
    1) Launch ResHacker, and open the executable file you want to modify.
    2) In the left side, you will see a list of resources. Select the folder icon for Bitmap.
    3) Select Action-> Save Bitmap Resources. This will save all the individual bitmap files, as well as .RC file. The .RC file is a pure text file that contains the mapping between the bitmap name and the resource number that it had assigned inside the exe file.
    4) Modify all the bitmaps using your favorite image editor.
    NOTE: Don't get discouraged, read the following which makes the import back into iGuidance real easy:
    5) Because ResHacker cannot import back an .RC file, you need to compile it into a .RES file, which ResHacker can import just fine. So... first copy the GoRC.exe file into the same folder where all your bitmaps and .rc are located. Assume c:\bitmaps\, and that you have a file bitmaps.rc inside.
    6) Open a cmd line (Start->Run, and type cmd). Go to the folder c:\bitmaps and then you are going to run this command:
    gorc.exe /r bitmaps.rc
    7) This will output a file bitmaps.res. Open ResHacker, Open the iGuidance executable application file, and select Action-> Update All Resources. Choose your .RES file, and save changes.
    This works with other resource types, such as dialogs etc.
    Piece of cake!
    -=J
    2002 Honda CR-V
    Spent so far: $1105.90
    ...or even Listen to my music
    wow, that's cool... thanks for sharing this.... can't wait to get my own copy of ig3....
      Nice, Thank you. As soon as CdRsKuLL finishes Freedom, (a skin for RoadRunner) I think I'll do up my copy of ig3 to match.
      7" TouchScreen Carputer
      Rockford Fosgate 1501BD and Rockford 551s
      12" MTX 9500 in a SS* or a 12" Brahma in a SS*
      ZAPCO COMPONENTS in front and RFs in rear
      2 YellowTops and a 200amp Iraggi Alternator
      *Snell Shell box from nolteaudio.com
        I keep getting this error. What am I doing wrong?
        CMD:
        C:\Documents and Settings\Front Room Stroke\Desktop\ig>gorc.exe /r bitmaps.rc
        GoRC.Exe Version 0.90.2 - Copyright Jeremy Gordon 1998/2006 - JG@JGnet.co.uk
        Error!
        Line 1739 of Resource Script (bitmaps.RC):-
        Invalid accelerator event:-
        VK_C
        RES file not made
          Something tells me that when you exported the bitmap resources from ResHacker (into a .RC file) you must have selected more than just the bitmap resources.
          When you export, select ONLY the Bitmap icon on the left, and then Save Bitmap Resources...
          Just to verify, open the .RC file you currently have. Do you see more than just bitmap assignments in there?
          2002 Honda CR-V
            ...cool trick!
            Cool trick Justintime!
            I'm just dealing with it...
            it makes easier everything!!!
            ...I was resizing iG icons and it works perfectly with photoshop batch actions!!!
            Live today like it is your last day, and behave as though you will live forever...
            my WEBSITE
            MapMonkey Dalai skin-preview-download ITA-email me for ENG
            Road Runner CrystalBlue skin-preview-beta release
              yep you're right. Thanks
                If someone hacks the pc / car puter version to let it access the outlook address book, please show Inav how to do it too. Maybe they can make it their v5.0 release.
                  justintime u are my hero!!
                  This is going to save me sooooooooooo much time.
                  beer replenishment fund
                  mp3car live search
                    It wouldn't have saved you (or me) any time if I didn't send ya the link to this thread! hahahah!!!!
                    My Fiero Build Thread
                      So where would one look if one wanted to see what everyone has done so far with IG4 and reshack? Im interested in seeing!
                      if your worried about making the edits publicly announced, just pm me. Im changing a few things my self trying to get it to look more like centrafuse... but im no pro.
                      ~0okami.Digital
                        Yes, has anyone hacked IG4 the way IG3 was?
                        Current Vehicle: 2007 Dodge Nitro
                        Second Vehicle: Sold it :( 2005 Dodge Ram 1500 Quad Cab
                        First Vehicle: 2003 Ford Ranger
