Palm VNC to control winamp ?
  • Palm VNC to control winamp ?
    i had a soft for my palm once that was suposed to show you the screen of your pc on the palm but i never got it to work i couldn't get the palm to connect to the PC but now i figured that out .
    HAS ANYONE EVER TRIED THE SAME THING ?
    Apple Ipod 20gig 4th gen black and white. Saves you lots of time. and a pocketpc with wifi for the ocasional email cheking and mapping at a hotspot.
    Tried it and got the same thing......nothing. The reason is because Palm VNC will only work over a normal TCP/IP network connection. I've read that you can set it up to link through your palm cradle ( as i'm guessing you are trying to do ) but it's supposed to be pretty complex. Try this link, i know it's for Win2K but it might help you out or at least give you an idea of what's involved.
    Connecting a Palm Pilot to Windows 2000
    Hope this helps you.
    GTI - Palm IIIe controlled with Radio faceplate hack for keyboard control of WinAmp w/ Vocal Genre playlist loading.
    VW Bus - 10.4" vga lcd. Loaded with same software as above.
      I use VNC a lot at work over a network, but have had it working at home fine, using the Palm to control the PC. It's hard work, as the screen area is very small, so a lot of scrolling is involved. Also, I've only had it working over a serial connection, so it's not amazingly fast.
      To get the Palm to connect, you need to run a Palm>TCP mapper. I use MochaPPP from http://www.mochasoft.dk/
      Once Mocha is set up (make sure Hotsync is closed first) and put the Palm in it's cradle (or plug in a serial lead to it) and Mocha should report a connection (you need a 'proper' cable because the DTR line is used to check the connection).
      Run the VNC server on the PC (make sure you download the correct version - you need the version with server-side scaling from http://www.btinternet.com/~harakan/PalmVNC/)
      Run VNC on the Palm, enter the IP address of the PC (you'll need TCP IP installed on the PC), and in a couple of seconds, you
      should see (part of) the windows desktop.
      It's a lot easier than it sounds. hope this helps.
      bum. broke it.
        I've not got VNC running on my CE device, but managed to use Mocha PPP mentioned above to control a Winamp http server from the PDA.
        The mocha PPP implementation seems pretty good IMO.
