Destinator 5 PC Zoomed (like MapStore, iGuidance)
  • Destinator 5 PC Zoomed (like MapStore, iGuidance)
    A new patch is coming, this for Destinator.
    Remember
    MapStore 3.5 NOT-Official Patch
    link ,
    and iGuidance Zoomer
    link
    I post some screenshots:
    without Zoom:
    with Zoom:
    without Zoom:
    with Zoom:
    without Zoom:
    with Zoom:
    without Zoom:
    with Zoom:
    In Centrafuse:
    without Zoom:
    with Zoom:
    without Zoom:
    with Zoom:
    without Zoom:
    with Zoom:
    without Zoom:
    with Zoom:
    Regards,
    JASL
      When will this be available and are we going to be able to change the language (i.e Greek) ?
      The road is long but we are getting there.
        It will be available this night, or tomorrow in the morning (GMT+1 ). I've just finished to program it, I would test in the car. I forgot the configuration dialog where you can change the zoom in real time:
        Regards
          PS: The language is selected in Destinator options. The program will not change that. If you have destinator in Greek, it will remain in greek.
          Regards.
            So, how is it coming along ?
              this is looking good.. I do prefer however the menu / 2d/3d buttons this guys done from this download, would be awesome if you could add these
              http://www.mp3car.com/vbulletin/atta...6&d=1156260953
              CdR
              Follow me on Twitter
              http://www.FreeICE.co.uk
                o also. how quick is it at re-sizing.. and when it does .. does it show everything where it should be like the zoom bar etc..
                CdR
                  A beta version of the patch is at http://www.cybersuricate.com
                  Regards
                    It scales fast. You can select differents scaling methods and the redrawing interval.
                    All should be showed where it should, see screenshots.
                    Test it and comment any problems.
                    Regards.
                      I tried out this application and I have the following comments
                      1. A little slow on on a 2Ghz/512mb system.
                      2. It would be good not to use the F1 to F4 keys for your app because they are internal hotkeys for the destinator application (We use them with the sendkey command from RoadRunner).
                      Apart from the top mentioned problems, the whole concept seems really good and I for one will certainly use this application if the above two are fixed.
                      Keep up the good work
                        What do you mean with a little slow?
                        I have a 2Ghz Athlon XP processor and it uses about 3% CPU.
                        You can change the repaint interval in the configuration dialog, by default it is 500ms.
                        If you put a smaller value, it will run faster. I set 1/2 by default because some frontend/players use a lot of CPU in a C3 1GHz. Frontend+music+gps+zoom...
                        But if your cpu is faster you can change the value to speed up it.
                        PS:l change the hotkeys.
                        Regards,
                        JASL
                          OK. slowing down fixed by changing the update time.
                          When will you upload the new version with the changed hotkeys?
                            Hotkeys will change in beta3, and virtual keyboard, full screen, some fixes and some more options. Suggestions are welcomed.
                            Now you have beta2 that fix a problem with RoadRunner.
                            Regards.
                              i tried your zoomer app beta and its very nice but i have some probs:
                              What do i have to add in Roadrunner config?? Should i use your zoomer app or the destinator.exe in external-gps config?? Whats the Window-name???
                              If i add your zoomer app and use "Destinator" as window-name it works however the buttons dont respond???
                              Did i make something wrong??
                              But cool app so far....only need a osk now...
