Help! LCD output messed up after using LCDprint.exe
  • Help! LCD output messed up after using LCDprint.exe
    After 2 solid days of wiring a Seiko2014, I finally got my character display running perfectly with winamp. The next step was to work on the start up display. I remembered hearing people using lcdprint to print a text doc to the screen while DOS was still booting windows. When I was testing this I executed lcdprint 378 20 4 start.txt and all I got was garbage! I tried running winamp again and it was nothing but garbage! HELP! I turned off the computer and it still displays just garbage when running winamp. Did I do something wrong with lcdprint?
    LCD print should not effect any of the settings for the winamp plugin (it's a really simple program, and doesn't do much). Your best bet is to check the cable etc, if you havn't already.
    Rob
    And you say people actually pay money for M$ Windows?
    www.mp3mini.co.uk (Does what it says on the URL) www.openclassic.co.uk (The new car, with zero rust!) www.rob-web.co.uk (My other site)
    Total re-design underway: on the whole progress is very slow as the car is taking up too much time :)
