Sony Ericcson AT codes over BT
  • Sony Ericcson AT codes over BT
    AT*EALR=3,1,2
    I am trying to listen to a call on my bt dongle from a 700i. I get the accepted result but am now stuck as to how to listen to the call via the pc.
    Anyone any ideas?
    Marc
    You have to connect the audio gateway. If you are using the standard bluetooth drivers that come with windows those will not work. You'll need the widcomm drivers. As well unless your phone supports concurrent serial and audio connections you will need to disconnect the serial connection first.
