directory sync
  • directory sync
    Im sure most of you have a ton of mp3s on your comp, and im sure most of you have the same on your carputer, I'm looking for an easy peice of reliable software that will compare your directory of music on your main computer and your directory of music on your carputer and sync them easiliy over the LAN.
    I'v seareched for something like this, but have only found crappy programs. Anybody have any suggestions?
    You're looking for robocopy. I run:
    robocopy E:\MP3 \\impee3\d\mp3 /PURGE
    and it syncs up the two directories based on the source directory. The /PURGE option will delete files on the destination drive that are not found in your source directory. AFAIK, it only works on NT/W2k/XP, but you can give it a shot if you're on 95/98.
    (You might have to rename the attachment to robocopy.rar to uncompress it. I renamed it to zip so I could upload it.)
    Don't Click
      tried downloading robocopy but it downloads a corrupt file...and i trieds renaming to robocopy.rar also??
      any other reliable syn programs out there?
        It's rar'ed instead of zipped. WinRAR has a better compression scheme, so I don't use WinZIP anymore.
        Right click -> Save As robocopy.RAR -> Use WinRAR to decompress it
        I had to rename it to zip to upload it.
        *Edit* I just tried downloading it and it worked fine. You might need WinRAR 3.x.
        Don't Click
          Worked fine for me too. I used UltimateZip.
          http://ultimatezip.com
          Nice free replacement for WinZip with support for RAR, ACE, CAB, TAR, GZ, and a bunch of others.
            in windows, instead of making a folder, you could make a briefcase/portfolio that you could sync with another briefcase/portfolio, right click -> create and there you go!
            My cars
              jol, could you elabortate? can this be done automatically?
              Silver 1999 Nissan Pathfinder!
              Completion: [*********-] 90%
              Everything working! Mobile MP3s ROCK!
              LEFT TO DO: Improve power on circuit, fix slow boot time
              - 550mhz PIII on Abit BH6
              - 128MB RAM
              - 40x4 Backlit Character LCD
              - 17 key numeric keypad - Repainted buttons
              - 2.1GB laptop drive for OS
              - 4.3GB drive for MP3s
              http://www.mp3car.com/usersites/bombboyer/ Redesigned, new pics!
                I'm working on it - I expect to have it done to workable alpha in a few days, with a beta in a week or so - I'm adding stuff like cddb sync and in fact any single file sync at the moment. Directories of mp3's were working well but were a bit slow so I removed them from the msync software I posted about here b4.
                Cheers
                Andrew
                Mediabox Hardware Project
                Current Stage: A complete redesign, although not much happening right now!
                Mediabox Software Project
                Status: Writing Sync Software (still) and playing around with interface
                To do: Far too much!
                  just a thing that came to my mind, check it out urself, right click->create->create new portfolio/briefcase...
                  My cars
                    Could someone explain how to make Robocopy copy files from DIR1 to DIR2, copying all sub-dirs too? Thanks!
                    1993 BMW 325is - 15.2sec
                      Try SyncBack. This is a great synchronisation app with GUI.
                      Stage 1:[||||||||||||||||||||] 100%
                      Epia M10000, Lilliput 7' TS (modded), Teac DV28-SL, Globalsat BU-303, Maxtor 40GB 7200rpm, 512 MB pc3200, M1-ATX, Kenwood KDC-W6527SE
                        thanks syncback si what i was looking for. no autowifi sync but good for now
                        Peep MY TYTE WHIP yo! It's got too many ill mods to list!
