Destinator for PC
  • Destinator for PC
    I'm wondering how it was possible to run the WM version on PC (using the C_Base.exe - or something like that- software)?
    I have Destinator 6 for WM and it looks WAY better than the older version and I have some programming knowledge but I'm just asking if anyone can give a tip on how it was possible?
    Many thanks in advance.
    Destinator 6 for WM is only for windows mobile.
    To Use Destinator 6 on your PC you have to use the SDK version.
    The only front end that use Destinator SDK with the new maps that I know are DestiPlus and Freedrive 2.0.
    For destiplus is available the 5.15 version that is a good level of development, for freedrive 2.0 at the moment is available only for authorized betatester
    CarPC in Progress [||||||||-] 90%
    Visit my Project
      I've got D6 embedded directly into RR using the maps from a legitimate copy of D6 and the executable & DLL's from CF.
      It gives far better map guidance than D3 (roundabouts actually work!) but I'm still trying to fathom out how to get speed cam warnings working.
        D6 maps maybe but not D6
        Laidback
        The ultimate CarPC - Wow!
          True, I think CF may use D5?
            Thanks. I have been doing some reading and I can't afford any SDK so.....
            Yeah I suppose CF uses D5. D6 maps work fine even on D3 (not sure if the guidance is better in D5 than D3 coz I only tried it on CF and it's doing a great job).
              How did you get D6 maps working with D3? They bombed out when I tried.
              Would be great if they worked with MapMonkey.
