Flickering screens
  • Flickering screens
    In the front-end I have written, each form (eg. CD player, FM Tuner etc.) is simply a JPG image and a load of transparent panels over the buttons, Play, pause etc.
    Everything works fine apart from when a form is 'shown' the transparent panels flicker as the form appears.
    How can I stop the flicker, is is because of using transparent panels. Therefore is it a case of changing all the panels into picture boxes and loading each picture box with the relevent part of the JPG?
    What do other front-ends do?
    ViVE - Volkswagen In Van Entertainment:
    VoomPC 2, VIA C7 2GHz
    7" Lilliput
    120Gb Sata drive
    1GB RAM
    [||||||||||] 100% - Planning
    [||||||||||] 100% - Software coding
    [||||||||||] 100% - Built
    (Always tweaking!)
    Hi portreathbeach,
    I do not know what programming language but I did a search of pscode.com and found the code I was using. It uses api's to paint stuff.
    Check it out I am sure it will help you.
    With kind regards,
    FG van Zeelst
    Check out My Custom Frontend
      Nice, thanks for that.
      I'm not bothering with transparent picture or panels now. I just detect what co-ordinates of the form are clicked and work out what 'button' that represents.
      7" Lilliput
      120Gb Sata drive
      1GB RAM
      (Always tweaking!)
