VB.NET -- Random Key Generator
  • VB.NET -- Random Key Generator
    Don't know if this is useful to anyone else, but I had a quick need for random strings of alphanumeric nonsense this morning, and opted to play around a create a silly class of my own to do it. Source code attached for the class. Nothing special... Used Visual Studio 2008 Express to create it.
    Example usage:
    Code:
    Dim KeyGen As New RandomKeyGenerator
    Dim myKey As String = KeyGen.Generate(40)
    Dim myKeyWithSeparator As String = KeyGen.Generate(40, 10)
    MsgBox(myKey, MsgBoxStyle.OkOnly, "New Key w/no Separator...")
    MsgBox(myKeyWithSeparator, MsgBoxStyle.OkOnly, "New Key with Separator...")
    Play with it, 'til it's broke.
    TextBox as MsgBox
    hi,
    you make a keygen what shot key in a MsgBox and i will upgrate it with a Generate Button and a TextBox but...
    this i will make to textBox lile so:
    TextBox(myKeyWithSeparator, TextBoxStyle.OkOnly, "New Key with Separator...")
    have you some ideas?
    p.s. im from germany thereforce my english is so badly..
      hi,
      p.s. im from germany thereforce my english is so badly.. and i think i double post sorry when not ignor this
        You want the value to appear in a TextBox? If that is what you want, then try this:
        Code:
        ' assume textbox is named txtKeyWithSeparator
        txtKeyWithSeparator.Text = myKeyWithSeparator
        MsgBox( ) is a function that pops u a message box. TextBox is a control on your window/form, and you will need to set the .Text property of it.
        Hope this helps.
