vb.net and .tlb
  • vb.net and .tlb
    I try to create a dll plugin for RR .
    I don't found how to configure the compilator to create in same time that the dll a .tlb file.
    If someone can help me ?
    thanks
    as far as I know the tlb is created when you register the dll.
    so your installer would create it
      With the example that is given with each RR release ., the tlb , xml etc... are not created .
        when you register the .dll with regasm thats when you get the tlb
        (and this should be done with an installer, plugins without installers = lazy programmers)
        when debugging in the IDE, you would have the build option of register for com checked
        and when u build it will be registered and a tlb created
        but that is ONLY for debugging
        -Thanks
        Mitch
        www.rush2112.net
        Sun, Come shine my way
        Wind, Carry me home
        The piece of me that died
        Will return To live again
          i have a good simple inno template for ride runner plugins...
          if you want to start with that, you would need to know how to use Inno Setup
          its simple enough, if you can program, you can figure out Inno
          -Thanks
          Mitch
          www.rush2112.net
          Wind, Carry me home
            Can you send me this template please ?
