Night / Day Skin Code:
  • Night / Day Skin Code:
    I don't know if this might be helpful to anyone but I struggled with the logic for quite sometime. I needed code to change skins from day to night or from night to day depending on when my app considered day or night.
    This code was added to a timer which already kept trac of the system time for other reasons.
    Code:
    'gui.day = 6:00 AM
    'gui.night = 5:45 PM
    '* Check to see if current time falls between 6AM and 5:45PM or 5:45PM and 6AM
     If buffer.Compare(System.DateTime.Now.TimeOfDay, gui.night.TimeOfDay) = 1 Or buffer.Compare(System.DateTime.Now.TimeOfDay, gui.day.TimeOfDay) = -1 Then
    '* Ok we're in night so lets see if we really need to change the skin over
                If Not gui.current_skin = "nightSKIN" Then
                    '* Looks like we're going to have to change the skin, call the sub
                    gui.change_skin("night")
                End If
            Else
    '* Hmm, must be the morning, boy that night flew by!
    '* Check to see if we need to change the skin to day
                If Not gui.current_skin = "daySKIN" Then
    '* Change skin over to day time
                    gui.change_skin("day")
                End If
            End If
    Progress [I will seriously never be done!]
    Via EPIA MII
    512MB RAM
    OEM GPS (embedded)
    nLite WinXP pro on
    1GB Extreme III CF card
    Carnetix 1260 startup/ DC-DC regulator
    Software: Still, re-Writing my existing front end in .Net
    Why not calculate the sunrise/sunset time, and then switch based on that (say +/- x mins from sunrise and +/- y mins from sunset)
    http://www.freevbcode.com/ShowCode.asp?ID=341
    all you need is latitude and longitude and a date
    |V1 Virtual Display|
    Hard work often pays off over time, laziness always pays off right now.
      You could do that, just add sunrise date instead of gui.day and sunset date instead of gui.night
      I posted this code because for what ever the reason the logic just wasn't popping into my head... It's pretty bad when my non-programming non-computer literate fiencee figures out the logic before me in a discussion we had about it...
      This code is just the base code... probably some day some random person will find it using google and will be very thankful !!!!
      Via EPIA MII
      512MB RAM
      OEM GPS (embedded)
      nLite WinXP pro on
        Funny to see this post. I was just wondering how to get the skins too change automatically from day to night. I have not been able to figure it out.
        Have you got it working?
        Chuck
          The logic I've posted is working. :-)
          Via EPIA MII
          512MB RAM
          OEM GPS (embedded)
          nLite WinXP pro on
            Why not just use GammaControl 1.7? and switch the skin and the GPS.
              Exactly
              I'm accepting feature requests, and some features are making it to the program, as you can see with the MM support
              PowerVoice v1 | NaviVoice Source
              GammaControl v2.4
              SKINbedder v3
              1995 Lexus SC300
                Well for starters, gamma control is an external application which I didn't write. It's much easier to encorperate code already in my app.
                This is the "coders corner" and its a peice of code I thought may be helpful to some so I just posted it. Use freely.
                Via EPIA MII
                512MB RAM
                OEM GPS (embedded)
                nLite WinXP pro on
                  So what are you doing then to change the interface? Just switching colors? I'm not to a point where I'm even ready to do this yet, but it would be nice to have ideas for when I get there.
                    I just looked at that sounded interesting.
                    Then I looked at it again and went to cry in a corner because my head hurt.
                    It has pages of 'stuff' about citys and lists of citys and numbers of citys.
                    I need a drink.
                    Doh!
                    Lez, more widely known as flez1966
                      I can post a Sunset/sunrise/civilian-twilight function written in delphi, if usefull to someone.
                      Now Galileo is real. Muhahahahaha :p
