two lines for drivers egalax xp 3.4.0.4329
  • two lines for drivers egalax xp 3.4.0.4329
    is to make a small adjustment driver of tuch panel.
    the tecnic department of EGALAX
    they do not understand to me
    because I want to change the world
    or they do not want to recognize its failures
    one is the following thing.
    beginning to driver tuch now panel: white screen 4 points fits,
    if point is not touched ningun they,en 1 minute loads driver automatical
    modification: black screen time maxim to fit to 4 points 1 second
    result: automatic load of driver in xp with previous adjustment
    advantages: it does not bother at sight mouse and tuch without problems
    my knowledge do not give for that modification if somebody sees it feasible I animate I believe that it can be of utility to many
    What language is this ?
    Now Galileo is real. Muhahahahaha :p
      wow
      EWF, HORM, MinLogon on XP.
      Zotac ION Atom N330, 2GB low-profile RAM, M3-ATX
      Win Embedded Std 2011 RC
      OCZ Vertex Turbo 30GB SSD
      Lilliput 629 Transflective, WRX Screen Mount
      BlueSoleil BT, i-Blue GM-2 GPS, DirectedHD Radio, Andrea Mic
      VoomPC 2
        Me no understood!
        We are, will have and forever will be...
        But not tommorrow!
          SOY ESPAÑOL Y NO ESCRIBO INGLES POR ESO RECURRO A LA TRADUCCION AUTOMATICA PERO PARECE QUE NO ME FUNCIONA BIEN
          pero si alguien sabe español aqui va mi exposicion
          alguien sabria hacer que la utilidad de ajuste de 4 puntos que se inicia al principio de win con los drivers de tuch panel hiciera esto
          iniciar con fondo negro pero con una duracion de SOLO 1 segundo
          asi se cargan automaticamente el driver del tuch casi sin tocar nada
            Now i get it!
            But not tommorrow!
              Hey ramalo si estas hablando de los drivers para touchscreen dejame decirte que algo anda mal con los que tienes, yo lo uso a diario y nunca hace esto.
              Por otro lado yo creo que tu TS utility esta en la carpeta de startup, entonces ocurre esto (analiza si ese es el caso, y borralos)
              Espero que sea de ayuda.
              Thanatos.
              RexBruMet Skin for FrodoPlayer
              Nissan Aux-in MOD
              Originally posted by bgoodman
              We're an international forum, post in whatever langauge you like.
                Thanatos.
                DAMN, this site gives support in Spanish. Dats tight.
                It actually brought a tear to my eye that we are ALL so helpful.
                Michael
                  Thanatos.
                  Nissan Aux-in MOD
                    Thanatos.
                    Although, for all I know, you could have cursed him out and told him to leave.
                    Michael
                      Nah, We all know that we here to help each other
                      BTW I remember you cursing me the other day in french
                      Thanatos.
                      Nissan Aux-in MOD
                        Ah ok, that was Spanish translated to english, okayyy. I feel like I should apologize formy first reply, but heck, I 'm French and English is definetely not my native language.
                          thanks for the understanding Thanatos.
                          the subject is that I want that:
                          I want that the utility of driver of tuch normally begins with win xp since it does now
                          but that makes with bottom black screen
                          and 1 second lasts single
                          then load automatic driver
                          thanks for everything, a españolito that ingles does not write
