Remote Code Creation for VB
  • Remote Code Creation for VB
    Is there a way to easily create a new portion of a program by remotely executing code in native format in vb
    Basically:
    I want the end user to be able to create a variable then VB write to a textfile
    open file
    dim myVar as Integer
    myVar= "555"
    close file
    then onload at runtime read from the txt file and create those variables
    is there an easy way or a module or class to do this or any other way to incorporate this
    Thanks in advance
    .______
    | '_ |__\___
    [(o)|___(o)] XB
    ._________
    | I__I I_I|_\__I
    [(o)______(o)]b VanPimpin'
    LostReceptions Apps D/L Here
    GPSGasoline- Rewriting
    CarPCNetwork
    Not really. It depends on what exactly you want to execute and why. You may want to look into VBA (VB for applications) integration which allows you to run external scripts in a way similar to this. With cunning design, you can allow access from the vba script back into your VB application. Another way is to write your own script interpreter.. not as scary as it sounds... or perhaps think about incorporating perl or java..
      Basically:
      open file
      myVar= "555"
      close file
      Thanks in advance
      yes it is posible
      check attatchments
      We Exist because there is no patch for human Stupidity !!
      We need you ALL Here !!
