vb.net :: detecting a usb or cd media
  • vb.net :: detecting a usb or cd media
    the end result of what i'm trying to develop is that when a thumb drive or cd-rom is inserted into the system, it fires an event that will allow me to search through the contents of this new media and check for particular filetypes...
    anyone have any thoughts? i've been searching for a few days and haven't really found anything pertaining to this particular line of thought...
    thanks in advance.
    You want to listen on the window for the HWND value. Look up these HWND values on msdn, i've managed to listen out for new media instered value.
    Can't remember the code sorry!
      Code:
          ' USB DEVICE DETECTION BELOW:
          Private WithEvents m_MediaConnectWatcher As ManagementEventWatcher
          Public Sub StartDetection()
              ' __InstanceOperationEvent will trap both Creation and Deletion of class instances
              Dim query2 As String = "SELECT * FROM __InstanceOperationEvent WITHIN 10 WHERE TargetInstance ISA ""Win32_DiskDrive"""
              m_MediaConnectWatcher = New ManagementEventWatcher(query2)
              m_MediaConnectWatcher.Start()
          End Sub
          Private Sub Arrived(ByVal sender As Object, ByVal e As System.Management.EventArrivedEventArgs) Handles m_MediaConnectWatcher.EventArrived
              Dim mbo, obj As ManagementBaseObject
              ' the first thing we have to do is figure out if this is a creation or deletion event
              mbo = CType(e.NewEvent, ManagementBaseObject)
              ' next we need a copy of the instance that was either created or deleted
              obj = CType(mbo("TargetInstance"), ManagementBaseObject)
              Select Case mbo.ClassPath.ClassName
                  Case "__InstanceCreationEvent"
                      If obj("InterfaceType") = "USB" Then
                          MsgBox(obj("Caption") & " (Drive letter " & GetDriveLetterFromDisk(obj("Name")) & ") has been plugged in")
                      Else
                          MsgBox(obj("InterfaceType"))
                      End If
                  Case "__InstanceDeletionEvent"
                          MsgBox(obj("Caption") & " has been unplugged")
                          If obj("Caption") = USBDriveName Then
                              USBDriveLetter = ""
                              USBDriveName = ""
                          End If
                      Else
                      End If
                  Case Else
                      MsgBox("nope: " & obj("Caption"))
              End Select
          End Sub
          Private Function GetDriveLetterFromDisk(ByVal Name As String) As String
              Dim oq_part, oq_disk As ObjectQuery
              Dim mos_part, mos_disk As ManagementObjectSearcher
              Dim obj_part, obj_disk As ManagementObject
              Dim ans As String
              ' WMI queries use the "\" as an escape charcter
              Name = Replace(Name, "\", "\\")
              ' First we map the Win32_DiskDrive instance with the association called
              ' Win32_DiskDriveToDiskPartition.  Then we map the Win23_DiskPartion
              ' instance with the assocation called Win32_LogicalDiskToPartition
              oq_part = New ObjectQuery("ASSOCIATORS OF {Win32_DiskDrive.DeviceID=""" & Name & """} WHERE AssocClass = Win32_DiskDriveToDiskPartition")
              mos_part = New ManagementObjectSearcher(oq_part)
              For Each obj_part In mos_part.Get()
                  oq_disk = New ObjectQuery("ASSOCIATORS OF {Win32_DiskPartition.DeviceID=""" & obj_part("DeviceID") & """} WHERE AssocClass = Win32_LogicalDiskToPartition")
                  mos_disk = New ManagementObjectSearcher(oq_disk)
                  For Each obj_disk In mos_disk.Get()
                      ans &= obj_disk("Name") & ","
                  Next
              Next
              Return ans.Trim(","c)
          End Function
      That should get you started for detecting USB devices
      Not sure exactly what import statements you will need, but probably 'Imports System.Management' and maybe others.
      As for CDROM:
      Code:
          Protected Overrides Sub WndProc(ByRef m As System.Windows.Forms.Message)
              If m.Msg = WM_DEVICECHANGE Then ' Detect CD
                  If (m.WParam.ToInt32() = DBT_DEVICEREMOVECOMPLETE) Then
                      MsgBox("CD Removal Complete!")
                  ElseIf (m.WParam.ToInt32() = DBT_DEVICEARRIVAL) Then
                      MsgBox("CD Now Avaiable!")
                  End If
              Else
                  MyBase.WndProc(m)
              End If
          End Sub
      Jarrod - Holden VX S!
        jarrod, fantastic! thanks so much. i had actually figured out the usb one, but the cd-rom snippet is the perfect size to fit snugly where i need it to.
          No problems, what features will this software have btw?
            sorry for the SUPER late response (thought mine was the last one in here)... at the moment, i'm writing a new frontend (haha, yeah, i know... ANOTHER frontend). i'm not sure whether or not i'll ever release it, or whether it'll be for vehicles other than bmw's or not. at the moment, i'm just playing around with things, seeing what i can do. just an experiment at the moment.
              haha, suuuuper late If a frontend thats available doesnt do the job for ya, code your own
                hello
                i use ur code but my asp.net 2.0 can not recognize the ManagementEventWatcher
                can tell me this is dll or ur genrated class
                if it is ur genrated class or dll then please send me that class or dll.
                if not then please tell me how to use this................
                [email protected]
                  USB Mouse Connection/Disconnection
                  Jarrod,
                  Thanks for posting this code - it works great for detecting USB keys. One thing I'm trying to do is figure out how to detect when a USB mouse is plugged in. I tried modifying the code to query Win32_PointingDevices and Win32_USBControllerDevice but doesn't seem to work. Any suggestions on how I can listen for a USB Mouse connect/disconnect?
                  Thanks again!
                  Adam
