I've installed WinXP MCE 2005 on my carPC!
  • I've installed WinXP MCE 2005 on my carPC!
    my carPC:
    VIA M10000/40G/512M/LILIPUT7"
    before activing, it is very very slow on my carpc
    after activing and regist, faster, but not as fast as win2kpro
    FM and TV are still not work now because of drivers
    it seems that MS should use SPECIAL driver for media center although my driver for xp works fine!
    here is a screen pic, hope I can upload, as I am using XP MCE2005 now
    here is the screen
    have to use low size
      I have a MII 1.2g and its slow on mine, one thing I did to speed it up was to disable ALOT or services from starting on my machine. Second thing I went into the settings for MCE and I disabled certain visual aspects such as button animation. I have not tried this yet but some of the load could be taken off of the cpu if you use a seperate video card with a GPU. Im not sure if all the load is from the graphics or from background processing.
      before the changes I would idle at about 90% CPU usage and now it idles at about 60% usage.
        really slow than win2kpro
          then use win2k and get a front end
          similar to MCE is Media Portal, I havnt used it yet.
          http://mediaportal.sourceforge.net/
          there is also a slew of other software which you can find on the software section of this website.
            I am already a frodoplayer 1.09 thakes3 user and plugin maker
            can not find fontend for carpc use better than FP1.09
              i been using media center2005 in my car. i love it
                yes, i was
                just the vote of 1 and 2
                  whoa media portal looks schweet
