MCE 2005 Replacement
  • MCE 2005 Replacement
    So I have MCE 2005 and its great. Bad thing is no DivX support. I can add a icon to open up the Divx playa but that doesnt have a cataloging feature like MCE does for mp3s and dvds.
    Question: is there a know hack/plug-in for cataloging my divX files?
    or
    is their a similar front-end that i could use just for divXor .iso?
    or
    Are you serious about the DivX support? That sucks. You might try media portal. http://mediaportal.sourceforge.net/ or meedio http://www.meedio.com/ or some other.
    There ain't no need to cry. Time's up. It's time to die....
      I have MCE 2005 and have hundreds of Divx movies. Might want to try downloading the codec again from divx.com.
      2008 Ford Expedition EL Ltd
      Carputer yanked from the Jeep and Denali and waiting to be installed in the Ford.
        try the divx codec and the AC3 codec. If Media Player supports it then MCE2005 does.
        Aura MR62 (F and R)
        My Current MP3s
        IamDefiler.com
          Thats all I use it for Divx, and DVD's.
            I have MCE 2005 and it'll even play real and quicktime if you set it up right.
            Status: 40%
            Car: 2006 Scion tC (Buying)
            CPU: AOpen Pandora/1.5 Cel M/1GB DDR2/Ipod Vid
            Screen: Lilliput 7"
            Power: Carnetix 1900
            GPS: Deluo GPS
            Software: nLiteXP, RR, IG, PhoCo
            XM: XM Direct
            http://www.chrispuckett.com/mp3car/
              Thats not necessarily true, media player will play a number of badly written codecs that MCE does not. Since mce renders directly to a directx texture, the codec must be able to output a stream in a particular pixel format that MCE can convert to a directx texture in. I have run into this DivX problem myself before depending on the exact version / variant of the codec installed even though the files played fine in media player.
              StreetDeck.com Developer (I am Chuck)
              Get StreetDeck at http://www.streetdeck.com
              The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
                How the hell did you get it to play Quicktime files?
                Aura MR62 (F and R)
                My Current MP3s
                IamDefiler.com
                  Installed QuickTime and Real Alternative then added the following registry entries to get extra file types:
                  Code:
                  Windows Registry Editor Version 5.00
                  [HKEY_CLASSES_ROOT\.divx]
                  @="divxFile"
                  "PerceivedType"="video"
                  [HKEY_CLASSES_ROOT\.mov]
                  @="mov_auto_file"
                  [HKEY_CLASSES_ROOT\.movie]
                  [HKEY_CLASSES_ROOT\.mpg4]
                  [HKEY_CLASSES_ROOT\.qti]
                  [HKEY_CLASSES_ROOT\.qtif]
                  [HKEY_CLASSES_ROOT\.r1m]
                  [HKEY_CLASSES_ROOT\.r3t]
                  [HKEY_CLASSES_ROOT\.rec]
                  [HKEY_CLASSES_ROOT\.rpm]
                  Status: 40%
                  Screen: Lilliput 7"
                  GPS: Deluo GPS
                  XM: XM Direct
                    Code:
                    @="divxFile"
                    @="mov_auto_file"
                    SLICK!!!! I've been trying to figure this out for some time now. THX!!!
                    Aura MR62 (F and R)
                    My Current MP3s
                    IamDefiler.com
                      3ivx codec will fix the divX problem.
                        Hell yeah, so have I. Good work!
                          to make things easier.. You could just download a codec pack.. One of the first things i do after installing Windows is installing K-Lite codec pack
                          here's a link
                          http://www.free-codecs.com/K_Lite_Co...k_download.htm
                          edit: didnt realize how old this was
                            Does MCE work on the Epia M10k board with onboard graphics?
                            This is what i wanna do
                            I have the Epia 10k Board with 1Gig Ram.
                            Epia M10k, 1GB RAM, 40GB HDD, 7" Touch, DVD-RW Drive, Bluetooth, GPS, GPRS, all neatly hidden away in my Audi S2
                              I believe it does. MCE will work with pretty much any graphics card. It's the TV capture card that MCE only works with certain ones.
                              Aura MR62 (F and R)
                              My Current MP3s
                              IamDefiler.com
