Media drive on EWF system
  • Media drive on EWF system
    When using EWF to protect a CF card, do you choose which drive you are protecting? If you have a seperate hard drive for media can you still save to that normally or do you have to type in the commands to disable EWF?
    I ask because I want to use centrafuse so if I add music to my hard drive (media drive) do I need to include the commands to disable EWF or no? I don't want to write unneccessarily to my CF drive but still want to be able to update media easily and within centrafuse + be able to save playlists.
    Thanks,
    Chris
    The XPe based I built for my work I have the D: drive unlocked for user profiles, temp drive and application installs. Not sure if using ewf on a XP would be any different, but I dont think so.
    You are able to only lock a single drive or all the drives, just change the commands pramaters.
    the ewf commands are: ewfmgr <drive-letter> -enable
    06 Galaxy Gray Si #0308
    CarPc Progress -
    10%---------50%---------100%
    -[XXXXXXXXXXXXXXXXXXXXXX]-
