is it posible?
  • is it posible?
    can i have a Custom OS, for example Centerfuse (Google it if you dont know) and launch Windows form that? so say your just in the car going from place to place, you just use Centerfuse, but if your going on a long drive or plain on using windows can boot windows?
    why would you want that?
    any way you could;
    -arrange something with dualboot
    -use some vitrual machine to load windows in
      Just make centrafuse your shell, then you will boot directly into it.
      Search the forms for "boot" and "front end" for how to.............
      Just FYI, Centrafuse is a program, not an OS.
      Leonardo Da Vinci
        To expound on what GreatWhite said...
        If you make Centrafuse (note that it's not Centerfuse, which is a punk band) your shell, you can setup EXPLORER.EXE to laucnch as an external program, giving you access to full-on Windows functionality for the times when you need it.
        Be aware that there is likely some functionality you may lose if you make the front-end software your shell.
        How about the Wiki?
          i was only using Centerfuse as an example, could you create your own OS and boot or run windows from with in that? for example could you create you a version of Linux with only your drivers that dose what you want it to and then 'turn on' windows if you want it?
            OK.
            First, please learn how to spell or at least pay attention to what you type. I case you don't know there are a lot of very educated people on this board. Proper grammar and spelling will go a long way towards getting answers here.
            Second, why would you want to do this? Are you under the impression that you will decrease boot times?
            If so, I'd look elsewhere than writing an entirely new OS. Most boot time is "eaten up" in the POST, something the OS has nothing to do with. Windows can be made to boot fairly quickly if configured correctly.
            Since you're asking such basic questions, I'm guessing you lack the skill to write an OS. Nothing personal, it's just that an OS is a huge project; very few people could do this without a large conglomerate behind them. So the subject of your post is moot.
            If you intend to use any of the popular front ends, be aware they run on windows. A different OS would necessitate a new front end. You may be able to use boot camp (as in MAC) or some other software, but a custom OS would require custom software.
            Unless you're far more talented at programming than it appears (or you have more cash lying around than you know what to do with), I'd stick to streamlining windows or the suggestions mentioned above.
            So, to your original question:
            possible?
            Yes.
            Practical?
            No.
            Again, nothing personal here.
            Cheers
            Leonardo Da Vinci
              I think he got a little twisted up in his question/answers.
              Originaly what I thought the OP meant was "is there a way to boot into Centrafuse and still have access to Windows".
              I believe the "set up explorer as an external app" comment above solved that msytery.
              If not, then its me who is lost . ..
              PDP1170/TRS80/Atari800XL/Amiga500/286/486/P2/P4/C2D/i7 still a newb (but an old newb, been doing this a while) working my way up to "Complete Newb"
                Switch between operating systems? Vmware?
                  If you're asking if this is possible, then you probably don't have the skills, backgound or expertise to pull it off.
                  Windoze is an OS. Linux is an OS.
                  Yes, you can use emulators in Linux to run Windoze in a Linux environment. You can also setup a dual-boot using LILO or another boot loader.
                  How about the Wiki?
                    ok... so you cant boot in one OS and then END that OS and Boot Another OS... got it...
                      Thats not the question you asked
                      Yes, you can boot one OS and end that os then BOOT another os, you would basicaly have two partitions and a boot menu asking you which os to boot to (and probably timing out to one as the default).
                      I have a question : Why you want to?
                        You still have to reboot.
                        Christmas Car Project 2008
                        ArrowDash Skin Worklog
                          Yup. Thought the boot <== in bold above illustrated that :-)
                            Centrafuse need Windows (XP) and .NET to run.
                            Why would you want to run Windows within another Windows?
                            If you want to do that, why not use VPC and load another OS?
                            Y2K Accord Dell GX150
                            EmoRebellion is a SCAMMER
                              are you able to boot win E and use this or must you boot Vista...
                              i looked a bit but didnt find any thing that told me...
