xp optimization with nlite
  • xp optimization with nlite
    Hi all, as the topic title say id like to know whats your settings for xp in your carpc
    definitely would like to know myself cause i want it faster. all i'm running is freeice
      u have installed xp full?
      tweaked with nlite is faster...
        Strait up XP with nothing turned off.
        Works for me.
        How about the Wiki?
          isnt the startup too long?
            a program called bootvis will help you fine tune your start up time. It's on the bottom of this page:
            http://majorgeeks.com/download.php?det=664
            Check out my CARPC: Project Diamond Plate
            Quick Reference:
            CPU Electrical Specs
            Power Supply Calculator
            Video Connections for newbies
            Temperature Converter
            Voltage Calculator
              Nope.
              Of course I use hibernation mode , so resume from hibernate is pretty quick.
              And "too long" is subjective. What is acceptable to me may not be acceptable to others.
              Define "too long".
              How about the Wiki?
                too long for me is +20 seconds
                id like to have the system ready in 20-s
                how about the power consumption in hibernate mode?
                  Zero power consumption with hibernate mode -- not to be confused with sleep mode which does consume power.
                  My machine loads from hibernate in about 5 seconds and then re-initializes in 3 seconds. Too bad my POST takes about 4-5 seconds.
                    and u have a full version of xp?
                      I'd get roughly a 10 to 15 second boot time with an nLited version of server 2003, no swap file, 512mb ram, and using EWF. Not bad for an 800mhz machine.
                      Tidder
                      Try RevFE
                        That's too fast, I need a few more seconds in the morning to warm up the car.
                        Quick Reference:
                        Voltage Calculator
                          Ha!!!
                            I noticed no difference with hibernate when I switched from full version of XP to a stripped down version of XP. I'm only using 512MB of ram to keep the hibernate file small.
                              ok, u know if a zotac 610i support this feature?
