Need help booting iso from grub!!!
  • Need help booting iso from grub!!!
    I am trying to edit my menu.1st so that I can use it to boot an ISO saved to my HDD as a menu option. I am triple booting(XP,Win 7, and Ubuntu 9.04). Ubuntu installs a recovery option by default. XP has to be manually installed, which I have done. Win 7 only has the option available from the CD.
    What I did was saved a copy of both the XP Recovery Console CD and the Win 7 Repair Disc CD to the root folder of my Ubuntu installation. I am trying to setup my carpc so that each OS has a recovery option available from the Grub boot menu(don't want to have to keep track of CD's should I need to repair an OS installation in the car). After hours of googling I have gotten close to what I'm looking to accomplish. Here is what my menu.1st looks like as of the moment....
    # menu.lst - See: grub(8), info grub, update-grub(8)
    # grub-install(8), grub-floppy(8),
    # grub-md5-crypt, /usr/share/doc/grub
    # and /usr/share/doc/grub-doc/.
    ## default num
    # Set the default entry to the entry number NUM. Numbering starts from 0, and
    # the entry number 0 is the default if the command is not used.
    # You can specify 'saved' instead of a number. In this case, the default entry
    # is the entry saved with the command 'savedefault'.
    # WARNING: If you are using dmraid do not use 'savedefault' or your
    # array will desync and will not let you boot your system.
    default 2
    ## timeout sec
    # Set a timeout, in SEC seconds, before automatically booting the default entry
    # (normally the first entry defined).
    timeout 10
    ## hiddenmenu
    # Hides the menu by default (press ESC to see the menu)
    #hiddenmenu
    # Pretty colours
    #color cyan/blue white/blue
    #A splash image for the menu
    splashimage=/boot/grub/splashimages/Splash.xpm.gz
    ## password ['--md5'] passwd
    # If used in the first section of a menu file, disable all interactive editing
    # control (menu entry editor and command-line) and entries protected by the
    # command 'lock'
    # e.g. password topsecret
    ## password --md5 $1$gLhU0/$aW78kHK1QfV3P2b2znUoe/
    # password topsecret
    # examples
    # title Windows 95/98/NT/2000
    # root (hd0,0)
    # makeactive
    # chainloader +1
    # title Linux
    # root (hd0,1)
    # kernel /vmlinuz root=/dev/hda2 ro
    # Put static boot stanzas before and/or after AUTOMAGIC KERNEL LIST
    ### BEGIN AUTOMAGIC KERNELS LIST
    ## lines between the AUTOMAGIC KERNELS LIST markers will be modified
    ## by the debian update-grub script except for the default options below
    ## DO NOT UNCOMMENT THEM, Just edit them to your needs
    ## ## Start Default Options ##
    ## default kernel options
    ## default kernel options for automagic boot options
    ## If you want special options for specific kernels use kopt_x_y_z
    ## where x.y.z is kernel version. Minor versions can be omitted.
    ## e.g. kopt=root=/dev/hda1 ro
    ## kopt_2_6_8=root=/dev/hdc1 ro
    ## kopt_2_6_8_2_686=root=/dev/hdc2 ro
    # kopt=root=UUID=fe3c0e7e-1e19-4702-b6cd-5bcd8bea9f18 ro
    ## default grub root device
    ## e.g. groot=(hd0,0)
    # groot=fe3c0e7e-1e19-4702-b6cd-5bcd8bea9f18
    ## should update-grub create alternative automagic boot options
    ## e.g. alternative=true
    ## alternative=false
    # alternative=true
    ## should update-grub lock alternative automagic boot options
    ## e.g. lockalternative=true
    ## lockalternative=false
    ## additional options to use with the default boot option, but not with the
    ## alternatives
    ## e.g. defoptions=vga=791 resume=/dev/hda5
    # defoptions=quiet splash
    ## should update-grub lock old automagic boot options
    ## e.g. lockold=false
    ## lockold=true
    # lockold=false
    ## Xen hypervisor options to use with the default Xen boot option
    # xenhopt=
    ## Xen Linux kernel options to use with the default Xen boot option
    # xenkopt=console=tty0
    ## altoption boot targets option
    ## multiple altoptions lines are allowed
    ## e.g. altoptions=(extra menu suffix) extra boot options
    ## altoptions=(recovery) single
    # altoptions=(recovery mode) single
    ## controls how many kernels should be put into the menu.lst
    ## only counts the first occurence of a kernel, not the
    ## alternative kernel options
    ## e.g. howmany=all
    ## howmany=7
    # howmany=all
    ## specify if running in Xen domU or have grub detect automatically
    ## update-grub will ignore non-xen kernels when running in domU and vice versa
    ## e.g. indomU=detect
    ## indomU=true
    ## indomU=false
    # indomU=detect
    ## should update-grub create memtest86 boot option
    ## e.g. memtest86=true
    ## memtest86=false
    # memtest86=false
    ## should update-grub adjust the value of the default booted system
    ## can be true or false
    # updatedefaultentry=false
    ## should update-grub add savedefault to the default options
    # savedefault=false
    ## ## End Default Options ##
    title 1) CarPC Operating Systems Menu
    root
    title __________________________________________________ ___________________
    root
    title Start My CarPC Using Windows XP Professional
    root (hd0,0)
    chainloader +1
    title Start My CarPC Using Windows 7 Ultimate
    root (hd0,3)
    chainloader +1
    title Start My CarPC Using Linux Ubuntu 9.04
    uuid fe3c0e7e-1e19-4702-b6cd-5bcd8bea9f18
    kernel /boot/vmlinuz-2.6.28-11-generic root=UUID=fe3c0e7e-1e19-4702-b6cd-5bcd8bea9f18 ro quiet splash
    initrd /boot/initrd.img-2.6.28-11-generic
    quiet
    ###This is the recovery options menu###
    root
    title 2) CarPC Emergency Recovery Options
    root
    root
    title Windows XP Professional Recovery
    drivemap --mem(hd0,2)/RecoveryConsole.iso (hd0,2)
    drivemap --hook
    chainloader (hd0,2) +1
    rootnoverify (hd0,2)
    boot
    title Windows 7 Ultimate Recovery
    drivemap --mem(hd0,2)/Win7RepairDisc.iso (hd0,2)
    drivemap --hook
    boot
    title Linux Ubuntu 9.04 Recovery
    kernel /boot/vmlinuz-2.6.28-11-generic root=UUID=fe3c0e7e-1e19-4702-b6cd-5bcd8bea9f18 ro single
    ### END DEBIAN AUTOMAGIC KERNELS LIST
    Linux(Learning the curve...Like when driving!!!)
    Worklog!!!http://www.mp3car.com/vbulletin/fabr...l-worklog.html
    i don't think grub can boot to an iso image to my knowledge.
    Former author of LinuxICE, nghost, nobdy.
    Current author of Automotive Message Broker (AMB).
    Works on Tizen IVI. Does not represent anyone or anything but himself.
      Here are some of the links I have read through on the subject...
      http://www.linuxquestions.org/questi...y-grub-367901/
      http://ubuntuforums.org/showthread.php?t=774539
      http://forums.whirlpool.net.au/archive/925285
      http://superuser.com/questions/15413...-boot-from-iso
      So far I get "Error 1: filename must be either an absolute pathname or blocklist"
      Am I missing something here tripzero?
      Any help will be appreciated...thanks in advance!!!
        This link may be be the best as far as accomplishing my goal...
        Any thoughts or tips????
