Trying to boot vhd's from grub! Almost there!!!!
  • Trying to boot vhd's from grub! Almost there!!!!
    I am trying to boot two separate vhd's from grub in order to have recovery options for XP and Windows 7 as bootable recovery menu options on my carpc. Here is my updated menu.1st file....
    # menu.lst - See: grub(8), info grub, update-grub(8)
    # grub-install(8), grub-floppy(8),
    # grub-md5-crypt, /usr/share/doc/grub
    # and /usr/share/doc/grub-doc/.
    ## default num
    # Set the default entry to the entry number NUM. Numbering starts from 0, and
    # the entry number 0 is the default if the command is not used.
    # You can specify 'saved' instead of a number. In this case, the default entry
    # is the entry saved with the command 'savedefault'.
    # WARNING: If you are using dmraid do not use 'savedefault' or your
    # array will desync and will not let you boot your system.
    default 2
    ## timeout sec
    # Set a timeout, in SEC seconds, before automatically booting the default entry
    # (normally the first entry defined).
    timeout 10
    ## hiddenmenu
    # Hides the menu by default (press ESC to see the menu)
    #hiddenmenu
    # Pretty colours
    #color cyan/blue white/blue
    #A splash image for the menu
    splashimage=/boot/grub/splashimages/Splash.xpm.gz
    ## password ['--md5'] passwd
    # If used in the first section of a menu file, disable all interactive editing
    # control (menu entry editor and command-line) and entries protected by the
    # command 'lock'
    # e.g. password topsecret
    ## password --md5 $1$gLhU0/$aW78kHK1QfV3P2b2znUoe/
    # password topsecret
    # examples
    # title Windows 95/98/NT/2000
    # root (hd0,0)
    # makeactive
    # chainloader +1
    # title Linux
    # root (hd0,1)
    # kernel /vmlinuz root=/dev/hda2 ro
    # Put static boot stanzas before and/or after AUTOMAGIC KERNEL LIST
    ### BEGIN AUTOMAGIC KERNELS LIST
    ## lines between the AUTOMAGIC KERNELS LIST markers will be modified
    ## by the debian update-grub script except for the default options below
    ## DO NOT UNCOMMENT THEM, Just edit them to your needs
    ## ## Start Default Options ##
    ## default kernel options
    ## default kernel options for automagic boot options
    ## If you want special options for specific kernels use kopt_x_y_z
    ## where x.y.z is kernel version. Minor versions can be omitted.
    ## e.g. kopt=root=/dev/hda1 ro
    ## kopt_2_6_8=root=/dev/hdc1 ro
    ## kopt_2_6_8_2_686=root=/dev/hdc2 ro
    # kopt=root=UUID=fe3c0e7e-1e19-4702-b6cd-5bcd8bea9f18 ro
    ## default grub root device
    ## e.g. groot=(hd0,0)
    # groot=fe3c0e7e-1e19-4702-b6cd-5bcd8bea9f18
    ## should update-grub create alternative automagic boot options
    ## e.g. alternative=true
    ## alternative=false
    # alternative=true
    ## should update-grub lock alternative automagic boot options
    ## e.g. lockalternative=true
    ## lockalternative=false
    ## additional options to use with the default boot option, but not with the
    ## alternatives
    ## e.g. defoptions=vga=791 resume=/dev/hda5
    # defoptions=quiet splash
    ## should update-grub lock old automagic boot options
    ## e.g. lockold=false
    ## lockold=true
    # lockold=false
    ## Xen hypervisor options to use with the default Xen boot option
    # xenhopt=
    ## Xen Linux kernel options to use with the default Xen boot option
    # xenkopt=console=tty0
    ## altoption boot targets option
    ## multiple altoptions lines are allowed
    ## e.g. altoptions=(extra menu suffix) extra boot options
    ## altoptions=(recovery) single
    # altoptions=(recovery mode) single
    ## controls how many kernels should be put into the menu.lst
    ## only counts the first occurence of a kernel, not the
    ## alternative kernel options
    ## e.g. howmany=all
    ## howmany=7
    # howmany=all
    ## specify if running in Xen domU or have grub detect automatically
    ## update-grub will ignore non-xen kernels when running in domU and vice versa
    ## e.g. indomU=detect
    ## indomU=true
    ## indomU=false
    # indomU=detect
    ## should update-grub create memtest86 boot option
    ## e.g. memtest86=true
    ## memtest86=false
    # memtest86=false
    ## should update-grub adjust the value of the default booted system
    ## can be true or false
    # updatedefaultentry=false
    ## should update-grub add savedefault to the default options
    # savedefault=false
    ## ## End Default Options ##
    title 1) CarPC Operating Systems Menu
    root
    title __________________________________________________ ___________________
    root
    title Start My CarPC Using Windows XP Professional
    root (hd0,0)
    chainloader +1
    title Start My CarPC Using Windows 7 Ultimate
    root (hd0,3)
    chainloader +1
    title Start My CarPC Using Linux Ubuntu 9.04
    uuid fe3c0e7e-1e19-4702-b6cd-5bcd8bea9f18
    kernel /boot/vmlinuz-2.6.28-11-generic root=UUID=fe3c0e7e-1e19-4702-b6cd-5bcd8bea9f18 ro quiet splash
    initrd /boot/initrd.img-2.6.28-11-generic
    quiet
    ###This is the recovery options menu###
    root
    title 2) CarPC Emergency Recovery Options
    root
    root
    title Windows XP Professional Recovery
    root (hd0,2)
    chainloader (hd0,2)/UbuntuXpRecovery.vhd/i386/SMSS.exe
    title Windows 7 Ultimate Recovery
    root (hd0,2)
    chainloader (hd0,2)/Ubuntu7Recovery.vhd/Sources/boot.wim
    title Linux Ubuntu 9.04 Recovery
    kernel /boot/vmlinuz-2.6.28-11-generic root=UUID=fe3c0e7e-1e19-4702-b6cd-5bcd8bea9f18 ro single
    ### END DEBIAN AUTOMAGIC KERNELS LIST###
    Grub won't boot iso's but will boot vhd's. I had to create the vhd's using the disk management tool in Windows 7. Both are fixed size vhd's since grub only supports these type virtual hard drives. I made a 50mb one for XP's recovery console cd and a 190mb one for the Windows 7 Recovery Disc. then I copied the content of the CD's to their respective vhd. I then saved both vhd's to the root folder of my Ubuntu installation. I was able to get both working in Windows 7 using EasyBCD, so I know they were made correctly. However, when I run them from the grub bootloader, I get the message that the file is not found from both menu options when I try to boot from them. Can someone take a look at my menu.1st and tell me what I'm missing here?
    UPDATE: going to try this and see if it works...
    device --mem(hd0,2)/UbuntuXpRecovery.vhd/i386/SMSS.exe
    device --hook
    chainloader (hd0,2)+1
    rootnoverify (hd0,2)
    boot
    device --mem(hd0,2)/Ubuntu7Recovery.vhd/Sources/boot.wim
    device --hook
    boot
    What do you think?
    Thanks in advance!!!
    Linux(Learning the curve...Like when driving!!!)
    Worklog!!!http://www.mp3car.com/vbulletin/fabr...l-worklog.html
