Curses To Via !
  • Curses To Via !
    well, spend quite a while last night getting a functional nLited windows to work. I still have yet to try the latest build but here is what I was having trouble with (you might benefit from this)
    on build 7 of my nlite it seemed like everything was going to work... My OEM GPS which is attached to an internal, com2 of my via MII10000 board was having an IRQ conflict after a fresh install. This was because I hadn't yet installed the via (4 in 1 drivers) which includes a set of instructions of IRQ's for the com ports among other important PCI data to the OS.
    Upon running the 4 in 1 setup, it was crashing.... Why was it crashing ?? because aparently the extractor utility is a 16 bit application !!!! WHAT THE CRAP !!!! who uses 16 bit aps nowa days ???
    On to build 8, setup utility doesnt crash, extracts the data but doesn't run... WHY ?? because with nLite 1.9.77 you also need to apply the 16 bit "patch just undernieth 16 bit aps"
    On to Build 9... I'll update you all to let you know if I've succedded.
    Progress [I will seriously never be done!]
    Via EPIA MII
    512MB RAM
    OEM GPS (embedded)
    nLite WinXP pro on
    1GB Extreme III CF card
    Carnetix 1260 startup/ DC-DC regulator
    Software: Still, re-Writing my existing front end in .Net
    Cool ... can post your nLite config when you're done?
    2004 4runner
      BTW I believe 4in1 Setup.exe is just selfextracting archive which can be unpacked using Winzip on your desktop machine. Then you could possibly install unpacked drivers via their INF files rather then via setup engine. No need for 16 bit support then.
        I think that there are ways to extract the .exe. When you do that, you should be able to load up the drivers from device manager. That's what people were froced to do when VIA introduced a bug into their exe file
        GammaControl v2.4
        SKINbedder v3
        1995 Lexus SC300
          once you unpack the files the setup is still 16 bit, i tried that in hopes it would work with my laptop and burned the extracted files to a cd.. still no luck..
          Via EPIA MII
          512MB RAM
          OEM GPS (embedded)
          nLite WinXP pro on
            My settings.ini
            with page file disabled on a completely fresh install I'm getting about 360MB (this is without moving ANYTHING, so you can definatly get this down to 250 with a little effort)
            Code:
            [Main]
            Env = 0.99.7 beta.1.1.4322.2032.Microsoft Windows NT 5.1.2600.0..en-US
            Target = Windows XP Professional SP2 - build 2180
            [Pages]
            Integrate a Service Pack
            Remove Components
            Unattended Setup
            Options and Tweaks
            Create a Bootable ISO
            [Components]
            ;# Applications #
            Accessibility Options
            Briefcase
            Calculator
            Charmap
            ClipBook Viewer
            Games
            Internet Games
            NT Backup
            Pinball
            Screensavers
            Wordpad
            ;# Drivers #
            Battery
            Bluetooth Support
            Cameras and Camcorders
            Display Adapters
            Display Adapters (old)
            Ethernet (LAN)
            Firewire (1394)
            IBM Thinkpad
            InfraRed
            ISDN
            Modems
            MultiFunctional
            Multi-port serial adapters
            Portable Audio
            Printers
            Scanners
            SCSI/RAID
            Sound Controllers
            Toshiba DVD decoder card
            Windows Image Acquisition (WIA)
            Wireless Ethernet (WLAN)
            ;# Internet Utilities #
            Client for Netware Networks
            Communication tools
            FrontPage Extensions
            Internet Connection Wizard
            Internet Explorer
            Internet Information Services (IIS)
            MSN Explorer
            Netmeeting
            NetShell Cmd-Tool
            Network Monitor Driver and Tools
            NWLink IPX/SPX/NetBIOS Protocol
            Outlook Express
            Peer-to-Peer
            Synchronization Manager
            Vector Graphics Rendering (VML)
            Web Folders
            Windows Messenger
            ;# Multimedia #
            Images and Backgrounds
            Luna Theme
            Media Center
            MIDI audio support
            Mouse Cursors
            Movie Maker
            Music Samples
            Old CDPlayer and Sound Recorder
            Paint
            Tablet PC
            Windows Media Player
            Windows Media Player 6.4
            Windows Sounds
            ;# Operating System Options #
            Desktop Cleanup Wizard
            Disk Cleanup
            DR Watson
            File and Settings Wizard
            Help
            Manual Install and Upgrade
            Printer Support
            Search Assistant
            Security Center
            Shell Media Handler
            Tour
            Web View
            ;# Services #
            Alerter
            Application Layer Gateway
            Autoupdate
            CTF Loader
            Distributed Link Tracking Client
            Distributed Transaction Coordinator (DTC)
            DNS Client
            Error Reporting
            Fax Services
            Imapi
            Indexing Service
            IPSEC Policy Agent
            Messenger
            Network DDE
            QoS RSVP
            Quality of Service (Qos)
            Remote Registry
            Removable Storage
            Secondary Logon
            Service Advertising Protocol
            SNMP
            TCP/IP NetBIOS Helper
            Telnet Server
            Terminal Services
            Uninterruptible Power Supply
            Universal Plug and Play
            Volume Shadow Copy
            WebClient
            Windows Firewall/Internet Connection Sharing (ICS)
            Windows Time
            ;# Language Support #
            Arabic
            Baltic
            Central Europe
            Chinese Simplified
            Chinese Traditional
            Cyrillic
            Georgian
            Greek
            Hebrew
            Indian
            Japanese
            Korean
            Thai
            Turkish
            Vietnamese
            Multilanguage Support (LANG dir)
            Service Pack Messages
            Input Method Editor
            ;# Directories #
            DOCS
            SUPPORT
            VALUEADD
            [KeepFiles]
            [RemoveFiles]
            [Options]
            ;# Desktop,Taskbar & Startmenu #
            ;# Experimental #
            ;# Explorer #
            ;# Security & Privacy #
            ;# Speed #
            ;# Visual Effects #
            ProfilesDir = "%SystemDrive%\Documents and Settings"
            ;#ISO maker#
            isovol = WInLITE
            isoatt = -allow-multidot -relaxed-filenames -allow-leading-dots -N -l -d -D -joliet-long -duplicates-once -no-emul-boot -b boot.bin -hide boot.bin -hide boot.catalog
            Via EPIA MII
            512MB RAM
            OEM GPS (embedded)
            nLite WinXP pro on
