PLEASE HELP, FREAKIN HOTLLAMA, can't get it to go away
  • PLEASE HELP, FREAKIN HOTLLAMA, can't get it to go away
    I installed something apparently that came with HotLlama media player, I think with one of the power DVD's I installed, but I uninstalled all of them, and it won't go away. Every time I stick a DVD in, it automatically wants to install it. And if I do the install, it will pop up every time I stick a DVD in, and I don't want that. Does anyone know what registry to remove this thing from, or how to make it dissapear from my life. Its driving me up the wall. I have done every search to find it on the computer, and searched the names of the files that came up in the task manager to find it, but nothing. I don't know much about registries, and need help bad.
    thanks,
    Round VIII - [IIIIIIIIII] 30% Have some parts for 300zx Sema car I don't own yet. Will have 10.4" & 7" screen, and more then you can believe. Will add updates to cleancustoms.com, will be sweet. My car is still same, but might change.
    you sure it came with the media player because a lot of DVD's come with some random software (forget what it's called) that is set for autorun every time you put the disc in (if you've got autorun on that is). what is the name of the software that keeps running when you put the disc in?
    EWF, HORM, MinLogon on XP.
    Zotac ION Atom N330, 2GB low-profile RAM, M3-ATX
    Win Embedded Std 2011 RC
    OCZ Vertex Turbo 30GB SSD
    Lilliput 629 Transflective, WRX Screen Mount
    BlueSoleil BT, i-Blue GM-2 GPS, DirectedHD Radio, Andrea Mic
    VoomPC 2
      Try different discs too, it's an easy way to figure out if the software that's trying to install is on your system or on the disk. Eg, if you've been 'testing' this with the same movie over and over again....
      If it IS the disk, just disable autorun for the drive.
      Chrysler 300 - Fabricating
      http://hallert.net/
