BMW Bootscreen
  • BMW Bootscreen
    here's what i use, but i can't seem to get it to work... help pls
    Brushed Metal for Centrafuse 1.4
    Brushed Aluminum for Centrafuse 1.4
    xenarc 700ts | via epia-m10k | audigy2 nx | holux gm-210 | usb wifi | 40gb 2.5" | slot-load dvd-cdrw | morex 3688 | opus 150w | centrafuse, iguidance
    Ok, well you have not really said much about the issue you are experiencing.
    With little or no background on the issue how can you expect that the forum members will respond to you?
    For instance,
    What Operating System are you running?
    Is this a Boot Screen that you are trying to have appear when Windows XP boots up?
    Is this a BIOS graphic that you are trying to integrate into your BIOS?
    What method have you used to either integrate into either the boot up screen or the BIOS?
    Lots of unanswered questions there.
      got it to work, thanks, just needed to save as 4-bit instead of 8-bit bitmap on photoshop...
        seriously, could you provide more info???
        I am happy that you "got it to work", but maybe you could elaborate on the problem and also how "you got it to work", so maybe we also can learn something
        C134 Case
        VIA EPIA M10000
        FrodoPlayer
        iGuidance + GPS
        7" touchscreen LCD
        2000 Mitsubishi Eclipse GT
        - V6 216hp
        - KYB-AGX adjustable struts
        - Konei Alloy 17" rims + Pirelli P-Zero's
        - AEM slotted brakes
        - AEM CAI
          also can you post it, so some of your bmw friends can use it? i would like to myself!
          Go on and do it, do it, Do it 'til you're satisfied,
          Whatever it is, do it, Do it 'til you're satisfied.
          CarPc progress |OOOOXCOOOO| 57%
            i resized the picture so it will look stretched at a normal monitor (4:3). when you load it up in your widescreen touchscreen, the bmw logo will look perfectly round.
            just right click on it and save the picture.
            instructions on how to replace your windows load screen is here:
            http://www.thetechguide.com/howto/xpbootlogo/
              My PC did not like yr file......XP recovery console later....all is good again.
              Had to remind myself of DOS commands, ahhhh the old days.
              What ver of XP was that for?
              VIA 1Gig,512mb,Wifi,40GB,OPUS,7" TS,7x6.5" monitors,OEM wiring&fusing,Digital TV,3G Internet, Front and Rear Camera,12v DC PS2.
                i guess you have to do it yourself. just save the bitmap and then backup your ntoskrnl.exe, and download resource hacker.
                boot in safe mode and run resource hacker. open up ntoskrnl.exe from your windows\system32 folder, and then replace the #1 bitmap with the bmw bitmap that you just downloaded.
                  same here, im frozen with no floppy drive. IM out of town now, but if you can save me some trouble, how did you run the recovery console? i dont even need that, i just need a to get to dos so i can rename the files.
                    Guys... you should give Stardock software's bootskin a try... It works very fast, requires no overhead and you can change your bootskin very rapidly. Just google stardock bootskin or here is the link:
                    http://www.stardock.com/products/bootskin/
                    Here is my bootscreen.. I had to convert it to a JPG to upload, just convert it back to a .bmp if you want to use it. I nixed the progress bar and credit to Micro$haft since it's a carputer.
                      Only really need console if you are using NTFS, DOS is fine for FAT32.
                      Recovery console is on WinXP cd, just boot from it and select R. Follow steps.
                      DONE.
                        anyone else tried that stardock software?
                        Project "Media-Z" : 99 Camaro Z28 (Click to View)
                          I used to use it.. works perfectly, didnt slow down anything as far as I could tell....
                          Roy
                          2005 Range Rover 4.4
                            ALL the Stardock suites are great !!!! I use them all
                            Object bar
                            Object Desktop
                            Object Dock
                            DesktopX
                            Bootskins
                            Logon screens
                            ++++++++ many more
                            checkout http://www.wincustomize.com for all sorts of goodies
