How To Get Rid (Or Replace) Of ALL Boot Screens...
  • How To Get Rid (Or Replace) Of ALL Boot Screens...
    Hi All.
    The question is :
    Can i get rid (or replace) of ALL the boot screens???
    I dont want to see neither the initial screen (the one that BIOS creates, i think, with the Mhz of processor, the RAM, the Drives, and all the sequence), nor the boot screen of XP, nor the "loading personall settings" etc etc.
    NONE of them.
    Also, when i shutdown or restart, i dont want to see the "saving your settings" and "windows is shutting down" screen.
    Is something (or better all) of the above possible?
    Thanks!
    Turn your screen off...
    Seriously, you could hook a relay up to a timing circuit so the screen doesn't start until Windows is running.
      I know, but i'd like a real solution...
      Thanks anyway.
        Bit more involved, but you could run an app at startup and shutdown (or just run an app at startup which closes with the computer) to control the display though serial port or similar.
          not possable with windows I have been trying for years if you write your own OS and bios firmware you can do it
          there is a way to change the boot screen in windows but the max resolution and color depth is very low and all the other windows screens can't be changed at all
            best way is put a timer on the screen power to prevent it coming on until the PC is past most of the boot. That way it will look more professional.
            OR even easier....
            have you noticed your usb mouse come on mid way during the winXP boot screen? Well you can easily make a new one of these screens with your car logo on etc etc - there are a few already out there. I am not usre if it due to usb power being turned on at thsi point or something to do with a mouse getting told to turn on (i am goingon my MS intelliemouse explorer 3 here btw) but if it is the former then it is easy to turn the monitor on at this point with a relay. If it is the latter then hack into a old mouse like the intellimouse that has leds and use the power to them to activate a relay. That way your screens will only turn on during the boot sequence which you will have customised.
              You can at least make the post show less through the bios... I have heard of people replacing the splash screen shown during bios...but youll hafta google to see if that is possible. that and the windows boot screen being changed would take care of startup... dont know about shutdown. Just cut power to the monitor first using one of the myriad ways.
              Carputer status: [-*---------]
              Im thinking laptop...
                Thanks guys for the answers.
                I'll keep searching though...
                I know that the Bios screen is hard (or impossible???) to remove/hide.
                I think the others are changeable (through software and editors, like reshacker maybe)...
                We'll see...
                  The BIOS screen can usually be changed... you could blank it. But it will depend on your motherboard, not all support custom boot logo's.
                    I've been struggling mostly with eliminating the HIBERNATION screen, which shows the windows logo etc... (when going INTO hibernation mode).
                    I did see one post here explaining how to eliminate that one, but it did not work for me.
                    2002 Honda CR-V
                    Spent so far: $1105.90
                    ...or even Listen to my music
                      still searching to find something...
                      For those who are interested, I found that the word "welcome" during logon, can be changed to anything you want. Also there are some interesting bitmaps there.
                      The file conaining these (and other interesting things...) is logonui.exe in C:\windows\system32
                      First make a backup! I suppose "playing" with such files is dangerous....
                      If you open it with reshacker, open the string table on the left. In #1, you'll find "1033". Click this and on the right you'll see some interesting things, for example:
                      7, "welcome"
                      This is the famous "welcome" during logon. Change it and.. vouala!
                      For a coder, maybe it would be interesting to check the UIFILE on the left. Open UIFILE, then 1000, then click 1033 and on the right there is some coding???
                      Anyway, its a bit difficult to find a solution for the shutdown screen.... It seems it has (almost) nothing to do with bitmaps... It has to do with borders, backgrounds, elements etc.
                      Someone who knows the things (a coder for example???) could find something...
                      I'll keep searching though and do whatever i can, trying to understand this structure...
                        http://www.mp3car.com/vbulletin/showthread.php?t=51635
                        posts 2 and 4 - change logon/off screen
                        http://www.geocities.com/thejjoelc/XPbootcolors.html
                        to replace your boot screen
                        http://www.mp3car.com/vbulletin/showthread.php?t=32328
                        info on replacing bios boot screens - not possible on all mobos
                        My 2002 F250 Install
                          Code:
                          Auto Logon Windows
                          Step 1: Click Start > Control Panel > Display > Screensaver
                          Step 2: Uncheck On resume, password protect (if you have a screensaver set)
                          Step 3: Click the Power button followed by the Advanced tab
                          Step 4: Uncheck Prompt for password when computer resumes from standby
                          Step 5: Using the Microsoft Powertoy called Tweak UI, select Logon > AutoLogon
                          Step 6: Enter your username and password (if any) and hit OK
                          Note: To suppress autologon, hold the shift key while the system is starting.
                          Is this just like minlogon?
                          2002 Mitsubishi Galant
                          Carputer Specs:
                          Via M10K
                          512mb Ram
                          60GB HDD
                          Souund Blaster Audigy2 NX
                          OPUS ITX PC Case
                            Thanks for the links!
                              Cheekz185
                              no, minlogon logs you on as the root user or something like that. It doesn't start as many services or processes personal profile things I think, therefore making it faster but slightly less funcitonal (my acpi shutdown doesn't work with it). This is just automatic logon to an account, including administrator accounts, as if you had typed in the user/password yourself.
