TinyXP Beast edition problem
  • TinyXP Beast edition problem
    well I installed the beast edition of tinyxp and it works great but I have one problem.
    when using any p2p program (im not asking for any links or anything so this shouldnt be illegal to ask) i have problems with the ports.
    lets put azureus for example. I try using a Port Test and no matter what I try it sais i have a NAT Problem. the problem is I dont have a Nat firewall and the firewall proggy I use is Sygate but I allowed azureus with it. the thing is I think that the problem is with the windows firewall which is basicly not there when I try to open it. so... what do I do?
    try using UPnP(universal Plug 'n Play), Its under the plugins menu on the menubar(Azureus).
    BTW: P2P is not illegal.
    2007 Honda Fit Sport 1.5L SOHC-VTEC
      still nothing, im tellin ya its gotta be that damn windows firewall which i cannot access cause its not there on this rls...
      --EDIT--
      I tried utorrent port test and its said:
      Welcome to the µTorrent Port Checker.
      A test will be performed on your computer to check if the specified port is opened.
      Checking port 32459 on XXX.XXX.XXX.XXX...
      Error! Port 32459 does not appear to be open.
        Silly question, what route out are you using? Phone?, wlan? are the ports blocked on there?
          i had the same problem with the udp port of emule..
          i`ve three pc connected via wireless and i have emule in a pc which receive the internet connection from one the other.
          i setted the firewall of the pc with direct internet connection so it open the udp port of emule only for the requested pc but emule is now using a low id!!
          finally, i had another problem:
          the tinyxp beast edition can see the other pc in WLAN and can have access to them and the other can also see it but they can`t have access to its files and directories. how can i do??
          really finally:
          i`m using total commander to connect to the ftp servers but with `tinyxp beast edition` total commander can`t connect itself to the ftp; probabli because the windows ftp has been removed from the installation.. i`m asking you if there is a patch for the ftp too.
          thanks
            Im using beast edition and utorrent. I also have the same problem but it will still work. Im DL at 400k, if that port is not open it still works you just dont get optimized setting
            AutoPC v1 (Retired) - AutoPC v2 (in progress) - www.shocknet.us
              yes, but in emule if you have a low id, the queue will never pass..
              and i`ve also the other two problems..
                tiny xp beast legality
                I just got the tiny xp beast from a friend and i was just wondering like does this os register with microsoft on its own without knowing or like has the registry been hacked as well?? it says that i can browse the web but i just need assurance ya know.. ive been getting torrents as well i just need to know is there anyway for MS to find out about this or what...thanks
                  NEVER update beastXP! Its stripped for a reason. MS would probably install a gigabyte of garbage on your fresh 400 mb install.
                    tinyxp beast nat problem
                    somebody had the same issue. disapeared after installing TinyXP Rev05
                      just Nlite your own XP for your hardware requirements. Works great for me!
                        um... you just need to port forward your router for the P2P software to work faster, stuff like azer and utorrent and bitcomit are all bit torrent programs, and each of them needs thier ports open in order to request new connections (and get faster DL speeds), failure to do so makes the program pretty much only request downloads from people who want downloads from you (thus only leeches) and in big pools.. that doesnt happen too much
                        goto portforward.com and it wil help you out on fixining the P2P problem you are having
                        2004 Impreza WRX CarPC Install
                        I am willing to host any legal downloads that may benefit the CarPC community - PM for info
                        "When you go 0-60 in 4.5 seconds, you don't need a made up character called fast. Thats what makes a Subaru, a Subaru."
                        DG4L
