problem after installing boot xp
  • problem after installing boot xp
    ok i installed boot xp and now when i turn on my computer before it starts windows it asks if i want to use xp home edition or backup xp home edition
    how do i make it go straight to xp home edition?and if i uninstall boot xp will it mess any thing up.
    nvm probl;em fixed i restored the boot.ini thing
      Sounds like you have an extra entry in your boot.ini file
      There are 2 options rightclick mycomputer then go Properties>Advanced>Startup&Recovery Settings and then either remove the offending OS's boot.ini entry or set the timer on the default OS to boot after 1 sec better option is to remove the offending OS ini setting though.
      Oops too late.....
