S3 vs. S4
  • S3 vs. S4
    What is the real difference in power consumption on these two modes? I have my MCE box at home running in S3 and it completely shuts down and starts up within 5-10 seconds. Will this mode work with a CarPC without draining the battery in the process?
    Carputer Progress:
    Re-do fabrication of screen [DONE]
    Add mini-USB and micro-USB power from M2-ATX [DONE]
    Teardown PC [100%]
    Add HDMI > VGA converter [0%]
    It all depends on teh PC hardware.
    How about the Wiki?
      Like what? Will some chips stay running during S3 while others won't?
      Carputer Progress:
      Teardown PC [100%]
        My computer in the car stays on pernamently, when the key is turned off the computer goes to s3 standby, drawing about 150mA. originally i had the power disconnect from the laptop, and it then run from the internal battery while on standby, lasting about 50 hours. but now i just have the laptop power supply turned on pernamently to the car battery because 150ma is nothing for the car battery.
        www.opticalnote.com
          I've been too afraid to try it - don't want my battery to die. Maybe I will try it now...hmm
          Edit: Well, I guess I forgot about all the features on my M2-ATX, it will shut it down completely if the battery level is too low, so I guess I'll give this a shot
          Carputer Progress:
          Teardown PC [100%]
            Ok, maybe I'm missing something, but I can't get my car pc to go into S3, just S4. My BIOS is set to S3 and I did the reg fix for USB in Windows, so I don't know what else I have to do. I have a VIA M10000 mboard...
            Carputer Progress:
            Teardown PC [100%]
              are you picking standby when you "shutdown" windows?
                I was reading other people's experiences on Annoyances.org and it hit me that I have mine forcing hibernation in Windows - DUH! I am going to try unchecking hibernation and make sure that Windows is set for standby on power off. I remember doing this before and it not working though, I maybe have to make sure my USB devices aren't enabled for wake...
                Carputer Progress:
                Teardown PC [100%]
                  I'm not sure how accurate these tests are, but this guy says that S3 takes just as much power as when the computer is shut off.
                  http://www.yafla.com/dennisforbes/On...umppo-exe.html
                  Carputer Progress:
                  Teardown PC [100%]
