CF as fixed drive
  • CF as fixed drive
    In the past, I have made a Sandisk Ultra II card into a fixed drive using the utility. However I have just bought another which fails to budge. It comes up with the error "SMI Model, FAIL".
    I fear that the SMI model may not be an athens based controller and am therefore doomed. This is a problem, as for some reason after several days of perfect operation, WinXP will just crash if its run on a removable drive (standby not enabled).
    Therefore does anyone know anything more on this issue, or perhaps able to suggest a cf card that appears as a fixed drive without any voodoo?
    is that a legit SanDisk card or a cheap knockoff from ebay? Ultra II's and Extreme I's both can be set to fixed.
    EWF, HORM, MinLogon on XP.
    Zotac ION Atom N330, 2GB low-profile RAM, M3-ATX
    Win Embedded Std 2011 RC
    OCZ Vertex Turbo 30GB SSD
    Lilliput 629 Transflective, WRX Screen Mount
    BlueSoleil BT, i-Blue GM-2 GPS, DirectedHD Radio, Andrea Mic
    VoomPC 2
      All I can tell you is an UltraII bought from Amazon marketplace, which has the model ID of "SMI Model". Placing that string on google does not come up with a load of hits about fake cards, as "hyperstone sandisk" does.
