bypassing the check for mouse/keyboard
  • bypassing the check for mouse/keyboard
    Ok so my computer has a default that if it doesn't have a mouse or keyboard plugged in. On startup it will say error: no keyboard found, and no mouse found. Then it takes an extra 5 seconds, and keeps on loading windows like it just realized there was a touchscreen installed.
    Is there anyway I can bypass this check for a mouse/keyboard? Maybe skip it some how?
    You should be able to disable error messages in the bios. My bios allows me to turn off the keyboard error specifically.
    Yeah google!
      I am running windows 2000. My BIOS doesn't offer much, but I'll check it out again tonight.
        What kind of mobo? My BIOS says something like Halt on error and you can pick all, keyboard/mouse or none.
        Carputer Project Status:
        0% - Mobo died on 2/17/08
        Check out the worklog for my '01 Pathfinder.
          yea, I dont have a BIOS set up that lets me pick this option. I press f5 for boot up options and it says boot from: Hard disk. and thats it....
          I have another one that says f2 for setup, but there is nothing under there about any keyboard/mouse setup.
            You are looking for an entry in the BIOS that says something like "halt on all errors" and you wnat to change that to "halt on no errors".
            The Car 2005 Scion xB
            The Truck 2004 GMC Canyon
              Should be something similar under the F2 option. May be a option under advanced config or something. What kind of motherboard? Make and model will help.
                Your entering the BIOS boot menu and not the BIOS itself. There will be another key to press on post that lets you into the BIOS proper, something like the DEL or F10 key
                Visit my site V8 Scimitar
                SP13000, 300GB SATA HD, 1GB DDR. Opus 150, K301 screen, Cisco WIFI, AQmax GPS, RoadRunner and FreeDrive, Sony MEX-R5 head unit. 4 years installed and it just keeps running!
                  or F1
                  AtmosUSA.biz, E-Cig Mods
                  "A great smoking alternative"
                    A last ditch option would be to take apart a keyboard and take the little circuit board out of it. Then shorten the cable and just plug the circuit board into the keyboard port. They usually don't warn if there is a keyboard and no mouse.
                    I am not sure if this will disable the touchscreen or not...is your touchscreen USB?
                    2006 Lancer Evolution IX MR In-Dash PC Project - WIP
                    Planning:
                    [----------] 100%
                    Purchasing:
                    [----------] 90%
                    Installation/Fab/Assembly (Revised v2):
                    [----------] 90%
                      Yea my touchscreen is USB and VGA. And I erally don't want to take this computer apart. It's a weird case.
                        OK, since you seem to be absolutely dead-set against sharing any info like make & model of your PC so we can help you, I will tell you how I do it in my BIOS:
                        Press F2 during Post
                        Select Standard BIOS Settings
                        Select Halt on Errors
                        Select none from the 3 choices (None, Keyboard, Keyboard + Mouse)
                        HTH
                          This is the computer I have :
                          http://cgi.ebay.com/ebaymotors/ws/eB...m=260187502255
                          I think its called HP E-PC.
                          Tonight, I will try f10 and f1 and f2 and all of the fs lol see if one goes to the BIOS.
                            my truckputer has the same thing. i solved it by plugging in my wireless keyboard dongle into my hub.
                              wireless keyboard dongle?
