The WinXPe Colab Installation instructions
This topic is closed.
  • The WinXPe Colab Installation instructions
    I've been lurking everywhere for an easy step by step way of installing winXPE. To no avail, i'm not doing ALOT of trial and errors. I got this from a pdf that from a different board, this is for installing a raid server running XPE.
    So if anyone wants to jump in and help me with their experiences, please post something like "add this component" or "here's a better way of doing that".
    so far here's the easiest way to install winXPe.
    i'm running this on a single machine with 2 HDDs. i think you can use a CF as a second hdd for this.
    (i'm trying to make a guide focused on carPCs.)
    - Install the WINXP and drivers completely. I mean everything. I dont think you can add any drivers after this but I'm still experimenting.
    - Put WINXP Embedded XP Disk1 in ODD.
    Run "setup" in Disk 1, and then click "Tools setup".
    After"Tools setup" completed, then click "Database Engine Setup".
    After"Database Engine Setup" completed, select "All programs\Startup\Service Manager", then
    click service icon in taskbar, click "Start/continue".
    - Put Disk2 in ODD, run setup in Disk2.Select "Database Setup".
    - Put Disk3 in ODD, run setup in Disk3.Select "Database Update".
    - In "C:\programm files\Windows Embedded\utilities", double click 'tap', then it will create "devices.pmq" automatically. (remember, this is on the same machine so copy tap.exe to a target machine if thats what you plan to use)
    - Select "All programs\Microsoft Windows Embedded Studio\Component Designer".
    Open "File", choose "Importů", import "devices.pmq", and input log file name, click "start".
    Save "devices".
    - Select "All programs\Microsoft Windows Embedded Studio\Component Database Manager"
    Import devices file that created, and then click "Import", then "close".
    - Select "All programs\Microsoft Windows Embedded Studio\Target Designer".
    Open "file", choose "New", click "OK", then search components that you want.
    * device manager
    * display control panel
    * Acpi multiprocer
    * power management
    * Date/Time control panel
    * keyboard &Mouse control panel
    * system control panel
    * task manager
    * users control panel
    * user interface core
    * sound recorder
    * TCP/IP utility
    * Directshow DVD/MPEG2
    * audio control panel
    * DirectX 9.0C
    * add hardware control panel
    * add/remove program control panel
    * FAT/FAT Format
    * .NET
    * Other Componets you feel like adding.
    Open "Configuration", choose "Check Dependencies".
    After "Check Dependencies" finished, there are 4 errors.
    Double click task name, select "NT loader", "English Language Support", "FAT Format", "Explorer Shell", "Minlogon", "Disk Something & Optical Disk Something"
    Open "Configuration", choose "Check Dependencies" again.
    Open "Configuration", choose "Build Target Image", and click "Build".
    - After "Build" finished, copy BOOTPREP file in "C:\Programs files\Windows Embedded\ Utilities" to "C:\Windows Embedded Image"
    - Copy all files in "Windows Embedded Image" to another disk that must be FAT32.
    - Boot from floppy to DOS, then active the partition which has system files.
    - Reboot to DOS, execute BOOTPREP file.
    - Boot from HDD. The Embedded Windows XP is completed.
    - Input use name" administrator ", then press "Enter" key after enter OS.
    - Copy folder "Windows Embedded Data" to another disk for installing the drivers.
    I'm going to edit later as to show the result of the test. This is geared towards a centrafuse frontend. You may want to modify this guide as you see fit. Not all device/drivers/configurations will be the same for everyone. They didnt make winXPE to be user-friendly but more user customizable. I ask for everyone else's support on this and i think this will be a good OS for faster boot times/stability/etc.
    thanks,
    dave
    EDIT:
    by using task manager instead of using explorer, you can avoid installing winlogon. since ur using your frontend as your shell, shouldnt be a problem.
    Code:
    Starting dependency auto-resolve at: 2/17/2008 5:15:56 PM...
    CFDB: 6.24 secs, 693 reqs. LAB: 7.19 secs, 3275 reqs, 78% hits, 200 entries
    Resolve complete, elapsed time: 15.56 seconds
    No errors or warnings
    Starting dependency check at: 2/17/2008 5:16:11 PM...
    Checking: "Base Component [Version 5.1.2600.1106, R1507]"...
    Checking: "devices [Version 1.0, R2]"...
    Checking: "Processor [Version 5.1.2600, R620]"...
    Checking: "ACPI Fixed Feature Button [Version 5.1.2600, R620]"...
    Checking: "Programmable interrupt controller [Version 5.1.2600, R620]"...
    Checking: "System timer [Version 5.1.2600, R620]"...
    Checking: "Direct memory access controller [Version 5.1.2600, R620]"...
    Checking: "Communications Port [Version 5.1.2600, R620]"...
    Checking: "System speaker [Version 5.1.2600, R620]"...
    Checking: "PCI bus [Version 5.1.2600, R620]"...
    Checking: "System CMOS/real time clock [Version 5.1.2600, R620]"...
    Checking: "System board [Version 5.1.2600, R620]"...
    Checking: "Motherboard resources [Version 5.1.2600, R620]"...
    Checking: "Numeric data processor [Version 5.1.2600, R620]"...
    Checking: "ACPI Fan [Version 5.1.2600, R620]"...
    Checking: "ACPI Power Button [Version 5.1.2600, R620]"...
    Checking: "ACPI Sleep Button [Version 5.1.2600, R620]"...
    Checking: "ACPI Thermal Zone [Version 5.1.2600, R620]"...
    Checking: "Microsoft ACPI-Compliant System [Version 5.1.2600, R620]"...
    Checking: "Dell E771a [Version 5.1.2600, R620]"...
    Checking: "Plug and Play Monitor [Version 5.1.2600, R620]"...
    Checking: "HID-compliant consumer control device [Version 5.1.2600, R620]"...
    Checking: "HID-compliant mouse [Version 5.1.2600, R620]"...
    Checking: "HID Keyboard Device [Version 5.1.2600, R620]"...
    Checking: "CD-ROM Drive [Version 5.1.2600, R620]"...
    Checking: "Disk drive [Version 5.1.2600, R620]"...
    Checking: "ISAPNP Read Data Port [Version 5.1.2600, R620]"...
    Checking: "PCI standard host CPU bridge [Version 5.1.2600, R620]"...
    Checking: "VIA Bus Master IDE Controller [Version 5.1.2600, R620]"...
    Checking: "VIA Rev 5 or later USB Universal Host Controller [Version 5.1.2600, R620]"...
    Checking: "VIA OHCI Compliant IEEE 1394 Host Controller [Version 5.1.2600, R620]"...
    Checking: "Standard Enhanced PCI to USB Host Controller [Version 5.1.2600.1106, R1806]"...
    Checking: "PCI standard ISA bridge [Version 5.1.2600, R620]"...
    Checking: "PCI standard PCI-to-PCI bridge [Version 5.1.2600, R620]"...
    Checking: "Primary IDE Channel [Version 5.1.2600, R620]"...
    Checking: "Secondary IDE Channel [Version 5.1.2600, R620]"...
    Checking: "ACPI Uniprocessor PC [Version 5.1.2600.1106, R1507]"...
    Checking: "Logical Disk Manager [Version 5.1.2600, R620]"...
    Checking: "Volume Manager [Version 5.1.2600, R620]"...
    Checking: "Audio Codecs [Version 5.1.2600, R620]"...
    Checking: "Legacy Audio Drivers [Version 5.1.2600, R620]"...
    Checking: "Media Control Devices [Version 5.1.2600, R620]"...
    Checking: "Legacy Video Capture Devices [Version 5.1.2600, R620]"...
    Checking: "Video Codecs [Version 5.1.2600, R620]"...
    Checking: "WAN Miniport (L2TP) [Version 5.1.2600, R620]"...
    Checking: "WAN Miniport (IP) [Version 5.1.2600, R620]"...
    Checking: "WAN Miniport (PPPOE) [Version 5.1.2600, R620]"...
    Checking: "WAN Miniport (PPTP) [Version 5.1.2600, R620]"...
    Checking: "Packet Scheduler Miniport [Version 5.1.2600, R620]"...
    Checking: "Direct Parallel [Version 5.1.2600, R620]"...
    Checking: "Terminal Server Device Redirector [Version 5.1.2600, R620]"...
    Checking: "Terminal Server Keyboard Driver [Version 5.1.2600, R620]"...
    Checking: "Terminal Server Mouse Driver [Version 5.1.2600, R620]"...
    Checking: "Plug and Play Software Device Enumerator [Version 5.1.2600, R620]"...
    Checking: "Microcode Update Device [Version 5.1.2600, R620]"...
    Checking: "Microsoft Kernel Audio Splitter [Version 5.1.2600, R620]"...
    Checking: "Microsoft Kernel Acoustic Echo Canceller [Version 5.1.2600, R620]"...
    Checking: "Microsoft Kernel GS Wavetable Synthesizer [Version 5.1.2600, R620]"...
    Checking: "Microsoft Kernel DLS Synthesizer [Version 5.1.2600, R620]"...
    Checking: "Microsoft Streaming Service Proxy [Version 5.1.2600, R620]"...
    Checking: "Microsoft Streaming Clock Proxy [Version 5.1.2600, R620]"...
    Checking: "Microsoft Kernel System Audio Device [Version 5.1.2600, R620]"...
    Checking: "Microsoft Kernel Wave Audio Mixer [Version 5.1.2600, R620]"...
    Checking: "Microsoft WINMM WDM Audio Compatibility Driver [Version 5.1.2600, R620]"...
    Checking: "Microsoft Streaming Quality Manager Proxy [Version 5.1.2600, R620]"...
    Checking: "RAS Async Adapter [Version 5.1.2600, R620]"...
    Checking: "Microsoft Kernel DRM Audio Descrambler [Version 5.1.2600, R620]"...
    Checking: "USB Root Hub [Version 5.1.2600, R620]"...
    Checking: "Unknown Device [Version 5.1.2600, R620]"...
    Checking: "USB Human Interface Device [Version 5.1.2600, R620]"...
    Checking: "USB Composite Device [Version 5.1.2600, R620]"...
    Checking: "USB Mass Storage Device [Version 5.1.2600, R620]"...
    Checking: "1394 Net Adapter [Version 5.1.2600, R620]"...
    Checking: "Primitive: Wmilib [Version 5.1.2600.1106, R1507]"...
    Checking: "Class Installer - Processors [Version 5.1.2600.1106, R1507]"...
    Checking: "Class Installer - System devices [Version 5.1.2600.1106, R1507]"...
    Checking: "Class Installer - Ports (COM & LPT) [Version 5.1.2600.1106, R1507]"...
    Checking: "Class Installer - Monitors [Version 5.1.2600.1106, R1507]"...
    Checking: "Microsoft Visual C++ Run Time [Version 5.1.2600.1106, R1507]"...
    Checking: "Primitive: Hid.dll [Version 5.1.2600.1106, R1507]"...
    Checking: "Primitive: Setupapi [Version 5.1.2600.1106, R1507]"...
    Checking: "Win32 API - Kernel [Version 5.1.2600.1106, R1507]"...
    Checking: "Primitive: Ntdll [Version 5.1.2600.1106, R1507]"...
    Checking: "Win32 API - User [Version 5.1.2600.1106, R1507]"...
    Checking: "Win32 API - Advanced [Version 5.1.2600.1106, R1507]"...
    Checking: "Class Installer - Human Interface Devices [Version 5.1.2600.1106, R1507]"...
    Checking: "Mouse Class Driver [Version 5.1.2600.1106, R1507]"...
    Checking: "Primitive: Hidparse.sys [Version 5.1.2600.1106, R1507]"...
    Checking: "Class Installer - Mice and other pointing devices [Version 5.1.2600.1106, R1507]"...
    Checking: "Keyboard Class Driver [Version 5.1.2600.1106, R1507]"...
    Checking: "Keyboard: United States English [Version 5.1.2600, R620]"...
    Checking: "Class Installer - Keyboards [Version 5.1.2600.1106, R1507]"...
    Checking: "Primitive: Cdrom.sys [Version 5.1.2600.1106, R1507]"...
    Checking: "Primitive: Ks.sys [Version 5.1.2600.1106, R1507]"...
    Checking: "Class Installer - DVD/CD-ROM drives [Version 5.1.2600.1106, R1507]"...
    Checking: "PnP (Kernel-mode) [Version 5.1.2600.1106, R1507]"...
    Checking: "Class Installer - Disk drives [Version 5.1.2600.1106, R1507]"...
    Checking: "Class Installer - IDE ATA/ATAPI controllers [Version 5.1.2600.1106, R1507]"...
    Checking: "Primitive: Usb.inf [Version 5.1.2600.1106, R1507]"...
    Checking: "Class Installer - Universal Serial Bus controllers [Version 5.1.2600.1106, R1507]"...
    Checking: "Primitive: Ohci1394.sys [Version 5.1.2600.1106, R1507]"...
    Checking: "Primitive: 1394bus.sys [Version 5.1.2600.1106, R1507]"...
    Checking: "TCP/IP Over 1394 [Version 5.1.2600.1106, R1507]"...
    Checking: "Class Installer - IEEE 1394 Bus host controllers [Version 5.1.2600.1106, R1507]"...
    Checking: "USB 2.0 [Version 5.1.2600.1106, R1507]"...
    Checking: "Primitive: Kdcom [Version 5.1.2600.1106, R1507]"...
    Checking: "Class Installer - Computer [Version 5.1.2600.1106, R1507]"...
    Checking: "NT Hardware Detect [Version 5.1.2600.1106, R1507]"...
    Checking: "VGA Boot Driver [Version 5.1.2600.1106, R1507]"...
    Checking: "File system recognizer [Version 5.1.2600.1106, R1507]"...
    Checking: "Disk Management Basic Volume Runtime [Version 5.1.2600, R620]"...
    Checking: "Disk Management Services [Version 5.1.2600, R620]"...
    Checking: "Disk Management Dynamic Volume Runtime [Version 5.1.2600, R620]"...
    Checking: "Class Installer - Sound, video and game controllers [Version 5.1.2600.1106, R1507]"...
    Checking: "Netrasa Inf [Version 5.1.2600, R620]"...
    Checking: "Dial-Up Networking Common Libraries [Version 5.1.2600.1106, R1507]"...
    Checking: "Class Installer - Network adapters [Version 5.1.2600.1106, R1507]"...
    Checking: "Dial-up Client for Windows [Version 5.1.2600, R620]"...
    Checking: "Quality of Service Traffic Control [Version 5.1.2600.1106, R1507]"...
    Checking: "Terminal Services Core [Version 5.1.2600.1106, R1507]"...
    Checking: "Class Installer - Stream [Version 5.1.2600, R620]"...
    Checking: "Intel Microcode Update Driver [Version 5.1.2600, R620]"...
    Checking: "Primitive: Portcls.sys [Version 5.1.2600.1106, R1507]"...
    Checking: "Primitive: Drmk.sys [Version 5.1.2600.1106, R1507]"...
    Checking: "Primitive: Hidclass.sys [Version 5.1.2600.1106, R1507]"...
    Checking: "TCP/IP Over 1394 INF Files [Version 5.1.2600, R620]"...
    Checking: "CoDevice Installer - System devices [Version 5.1.2600.1106, R1507]"...
    Checking: "RPC Local Support [Version 5.1.2600.1106, R1507]"...
    Checking: "Win32 API - GDI [Version 5.1.2600.1106, R1507]"...
    Checking: "Windows subsystem [Version 5.1.2600.1106, R1507]"...
    Checking: "Embedded Trust [Version 5.1.2600.1106, R1507]"...
    Checking: "VGA Save [Version 5.1.2600.1106, R1507]"...
    Checking: "First Boot Agent (FBA) [Version 5.1.2600.1106, R1507]"...
    Checking: "Primitive: Imm32 [Version 5.1.2600.1106, R1507]"...
    Checking: "Primitive: Winsta [Version 5.1.2600.1106, R1507]"...
    Checking: "Primitive: Version [Version 5.1.2600.1106, R1507]"...
    Checking: "Primitive: Msimg32 [Version 5.1.2600.1106, R1507]"...
    Checking: "Primitive: Dxapi.sys [Version 5.1.2600.1106, R1507]"...
    Checking: "CoDevice Installer - Mice and other pointing devices [Version 5.1.2600.1106, R1507]"...
    Checking: "CoDevice Installer - Keyboards [Version 5.1.2600.1106, R1507]"...
    Checking: "CoDevice Installer - DVD/CD-ROM drives [Version 5.1.2600.1106, R1507]"...
    Checking: "CoDevice Installer - Disk drives [Version 5.1.2600.1106, R1507]"...
    Checking: "CoDevice Installer - IDE ATA/ATAPI controllers [Version 5.1.2600.1106, R1507]"...
    Checking: "Ndis [Version 5.1.2600.1106, R1507]"...
    Checking: "TCP/IP Networking [Version 5.1.2600.1106, R1507]"...
    Checking: "Class Installer - Storage volumes [Version 5.1.2600.1106, R1507]"...
    Checking: "Partition Manager [Version 5.1.2600.1106, R1507]"...
    Checking: "I/O Error Log Messages [Version 5.1.2600, R620]"...
    Checking: "Primitive: Ole32 [Version 5.1.2600.1106, R1507]"...
    Checking: "Primitive: Clusapi [Version 5.1.2600.1106, R1507]"...
    Checking: "Primitive: Osuninst [Version 5.1.2600, R620]"...
    Checking: "Service Control Manager (SCM) [Version 5.1.2600.1106, R1507]"...
    Checking: "RPC Server [Version 5.1.2600.1106, R1507]"...
    Checking: "Primitive: Netapi32 [Version 5.1.2600.1106, R1507]"...
    Checking: "Local Security Authority Subsystem (LSASS) [Version 5.1.2600.1106, R1507]"...
    Checking: "Routing Common Files [Version 5.1.2600, R620]"...
    Checking: "Primitive: Rasapi32 [Version 5.1.2600.1106, R1507]"...
    Checking: "Primitive: Mprapi [Version 5.1.2600, R620]"...
    Checking: "Primitive: Shlwapi [Version 5.1.2600.1106, R1507]"...
    Checking: "Primitive: Crypt32 [Version 5.1.2600.1106, R1507]"...
    Checking: "Primitive: CryptUI [Version 5.1.2600.1106, R1507]"...
    Checking: "Active Template Library (ATL) [Version 5.1.2600.1106, R1507]"...
    Checking: "Primitive: Userenv [Version 5.1.2600.1106, R1507]"...
    Checking: "System Event Notification Service (SENS) [Version 5.1.2600.1106, R1507]"...
    Checking: "Primitive: Ws2_32 [Version 5.1.2600.1106, R1507]"...
    Checking: "Primitive: Rasman [Version 5.1.2600.1106, R1507]"...
    Checking: "Primitive: Ntlsapi [Version 5.1.2600.1106, R1507]"...
    Checking: "Primitive: Dnsapi [Version 5.1.2600.1106, R1507]"...
    Checking: "Transport Driver Interface [Version 5.1.2600, R620]"...
    Checking: "Primitive: Tapi32 [Version 5.1.2600.1106, R1507]"...
    Checking: "Common Control Libraries Version 5 [Version 5.1.2600.1106, R1507]"...
    Checking: "Primitive: Winscard [Version 5.1.2600.1106, R1507]"...
    Checking: "Primitive: Secur32 [Version 5.1.2600.1106, R1507]"...
    Checking: "Security Accounts Manager Server Library [Version 5.1.2600, R620]"...
    Checking: "Primitive: Oleaut32 [Version 5.1.2600.1106, R1507]"...
    Checking: "Primitive: Shell32 [Version 5.1.2600.1106, R1507]"...
    Checking: "Common File Dialogs [Version 5.1.2600.1106, R1507]"...
    Checking: "Primitive: Mpr [Version 5.1.2600.1106, R1507]"...
    Checking: "Primitive: Wsock32 [Version 5.1.2600, R620]"...
    Checking: "Active Directory Service Interface (ADSI) Core [Version 5.1.2600.1106, R1507]"...
    Checking: "Primitive: Wmi [Version 5.1.2600.1106, R1507]"...
    Checking: "Primitive: Netman [Version 5.1.2600.1106, R1507]"...
    Checking: "Microsoft Foundation Class Library (MFC) [Version 5.1.2600, R620]"...
    Checking: "Microsoft Visual C++ Run Time (Legacy) [Version 5.1.2600, R620]"...
    Checking: "Primitive: Iphlpapi [Version 5.1.2600.1106, R1507]"...
    Checking: "Security Accounts Manager Client [Version 5.1.2600.1106, R1507]"...
    Checking: "Primitive: Netcfgx [Version 5.1.2600.1106, R1507]"...
    Checking: "IP Security Services [Version 5.1.2600.1106, R1507]"...
    Checking: "Netrass Inf [Version 5.1.2600.1106, R1507]"...
    Checking: "Netrast Inf [Version 5.1.2600, R620]"...
    Checking: "Network Configuration [Version 5.1.2600.1106, R1507]"...
    Checking: "Primitive: SWENINST [Version 5.1.2600.1106, R1507]"...
    Checking: "Telephony [Version 5.1.2600.1106, R1507]"...
    Checking: "Simple Network Management Protocol (SNMP) [Version 5.1.2600.1106, R1507]"...
    Checking: "TAPI 2.2 Client [Version 5.1.2600, R620]"...
    Checking: "Primitive: Icmp [Version 5.1.2600.1106, R1507]"...
    Checking: "Netpschd Inf [Version 5.1.2600, R620]"...
    Checking: "Generic Packet Classifier [Version 5.1.2600, R620]"...
    Checking: "Terminal Services Runtime [Version 5.1.2600.1106, R1507]"...
    Checking: "Primitive: AuthZ [Version 5.1.2600.1106, R1507]"...
    Checking: "Microsoft Audio Compression Manager (MME Core) [Version 5.1.2600.1106, R1507]"...
    Checking: "Primitive: Ksecdd [Version 5.1.2600.1106, R1507]"...
    Checking: "Primitive: Winmm [Version 5.1.2600.1106, R1507]"...
    Checking: "Primitive: Winspool [Version 5.1.2600.1106, R1507]"...
    Checking: "NPFS [Version 5.1.2600.1106, R1507]"...
    Checking: "Primitive: Mscms [Version 5.1.2600.1106, R1507]"...
    Checking: "Fonts: Fonts Microsoft_San_Serif [Version 5.1.2600, R620]"...
    Checking: "Fonts: Fonts Tahoma [Version 5.1.2600.1106, R1507]"...
    Checking: "Fonts: Fonts tahoma_bold [Version 5.1.2600.1106, R1507]"...
    Checking: "Fonts: Western Europe font substitute [Version 5.1.2600, R620]"...
    Checking: "Font:  Marlett [Version 5.1.2600, R620]"...
    Checking: "NLS: Core Files [Version 5.1.2600.1106, R1507]"...
    Checking: "Primitive: Dxg [Version 5.1.2600.1106, R1507]"...
    Checking: "Primitive: Dxgthk [Version 5.1.2600, R620]"...
    Checking: "Primitive: SxS [Version 5.1.2600.1106, R1507]"...
    Checking: "Client / Server Runtime (Console) [Version 5.1.2600.1106, R1507]"...
    Checking: "Session Manager (Windows subsystem) [Version 5.1.2600.1106, R1507]"...
    Checking: "COM Server Registration [Version 5.1.2600.1106, R1507]"...
    Checking: "Fonts:vgaoem_fon [Version 5.1.2600, R620]"...
    Checking: "Primitive: Pidgen [Version 5.1.2600.1106, R1507]"...
    Checking: "Windows Sockets [Version 5.1.2600, R620]"...
    Checking: "Netbios over TCP/IP [Version 5.1.2600.1106, R1507]"...
    Checking: "Nettcpip Inf [Version 5.1.2600, R620]"...
    Checking: "Primitive: Mswsock [Version 5.1.2600, R620]"...
    Checking: "DHCP Client Service [Version 5.1.2600.1106, R1507]"...
    Checking: "FBA: SCE [Version 5.1.2600.1106, R1507]"...
    Checking: "Primitive: Cabinet [Version 5.1.2600.1106, R1507]"...
    Checking: "Primitive: Ncobjapi [Version 5.1.2600.1106, R1507]"...
    Checking: "Primitive: Umpnpmgr [Version 5.1.2600.1106, R1507]"...
    Checking: "Windows Security Configuration Editor Engine [Version 5.1.2600.1106, R1507]"...
    Checking: "Primitive: NetApi [Version 5.1.2600.1106, R1507]"...
    Checking: "Primitive: Netrap [Version 5.1.2600.1106, R1507]"...
    Checking: "Primitive: Wldap32 [Version 5.1.2600.1106, R1507]"...
    Checking: "Lightweight Directory Access Protocol (LDAP) client [Version 5.1.2600.1106, R1507]"...
    Checking: "Windows NT MARTA Provider [Version 5.1.2600.1106, R1507]"...
    Checking: "Primitive: Cryptdll [Version 5.1.2600.1106, R1507]"...
    Checking: "Primitive: Msctf [Version 5.1.2600.1106, R1507]"...
    Checking: "Primitive: Esent [Version 5.1.2600.1106, R1507]"...
    Checking: "Primitive: Msasn1 [Version 5.1.2600.1106, R1507]"...
    Checking: "Wininet Library [Version 5.1.2600.1106, R1507]"...
    Checking: "Primitive: Wintrust [Version 5.1.2600.1106, R1507]"...
    Checking: "Ole Automation [Version 5.1.2600, R620]"...
    Checking: "Group Policy Core - Support Files [Version 5.1.2600, R620]"...
    Checking: "COM Base [Version 5.1.2600, R620]"...
    Checking: "Primitive: Ws2Help [Version 5.1.2600.1106, R1507]"...
    Checking: "Common Control Libraries Version 6  [1.0.0.0] [Version 5.1.2600.1106, R1507]"...
    Checking: "Primitive: Wtsapi32 [Version 5.1.2600.1106, R1507]"...
    Checking: "Primitive: Security [Version 5.1.2600.1106, R1507]"...
    Checking: "Primitive: uxtheme [Version 5.1.2600.1106, R1507]"...
    Checking: "Primitive: Imagehlp [Version 5.1.2600.1106, R1507]"...
    Checking: "Primitive: Wzcsvc [Version 5.1.2600.1106, R1507]"...
    Checking: "Primitive: NetClass [Version 5.1.2600.1106, R1507]"...
    Checking: "Kernel Mode Crypto Driver for RSA [Version 5.1.2600, R620]"...
    Checking: "Primitive: Psapi [Version 5.1.2600.1106, R1507]"...
    Checking: "PnP (User-mode) [Version 5.1.2600.1106, R1507]"...
    Checking: "Microsoft Management Console (MMC) [Version 5.1.2600.1106, R1507]"...
    Checking: "Event Log [Version 5.1.2600.1106, R1507]"...
    Checking: "Remote Registry Service [Version 5.1.2600, R620]"...
    Checking: "TAPI User Interface [Version 5.1.2600, R620]"...
    Checking: "H323 Telephony Service Provider [Version 5.1.2600, R620]"...
    Checking: "HID Phone Telephony Service Provider [Version 5.1.2600, R620]"...
    Checking: "IP Conference Telephony Service Provider [Version 5.1.2600, R620]"...
    Checking: "Unimodem [Version 5.1.2600.1106, R1507]"...
    Checking: "Netgpc Inf [Version 5.1.2600, R620]"...
    Checking: "Primitive: Utildll [Version 5.1.2600.1106, R1507]"...
    Checking: "Primitive: Regapi [Version 5.1.2600.1106, R1507]"...
    Checking: "Class Install Library - Msports [Version 5.1.2600.1106, R1507]"...
    Checking: "Class Install Library - Desk [Version 5.1.2600.1106, R1507]"...
    Checking: "Class Install Library - System Devices [Version 5.1.2600.1106, R1507]"...
    Checking: "Class Install Library - Storprop [Version 5.1.2600.1106, R1507]"...
    Checking: "Class Install Library - Mmsys [Version 5.1.2600.1106, R1507]"...
    Checking: "Class Install Library - Netcfgx [Version 5.1.2600.1106, R1507]"...
    Checking: "NLS: Locale Map IDs [Version 5.1.2600, R620]"...
    Checking: "Regional and Language Options [Version 5.1.2600.1106, R1507]"...
    Checking: "NLS: Time Zones [Version 5.1.2600, R621]"...
    Checking: "Fonts: EGA [Version 5.1.2600, R620]"...
    Checking: "Primitive: Regsvr32 [Version 5.1.2600.1106, R1507]"...
    Checking: "Primitive: Rundll32 [Version 5.1.2600.1106, R1507]"...
    Checking: "Primitive: Winsock [Version 5.1.2600, R620]"...
    Checking: "Primitive: Afd [Version 5.1.2600.1106, R1507]"...
    Checking: "Primitive: FBASec [Version 5.1.2600.1106, R1507]"...
    Checking: "Primitive: Digest [Version 5.1.2600.1106, R1507]"...
    Checking: "Primitive: Msvcrt40 [Version 5.1.2600.1106, R1507]"...
    Checking: "Primitive: Pstorsvc [Version 5.1.2600.1106, R1507]"...
    Checking: "Netlogon/NetJoin [Version 5.1.2600.1106, R1507]"...
    Checking: "Windows Security Configuration Editor Client Engine [Version 5.1.2600.1106, R1507]"...
    Checking: "Standard Template Libraries (STL) [Version 5.1.2600.1106, R1507]"...
    Checking: "Urlmon Library [Version 5.1.2600.1106, R1507]"...
    Checking: "Common Control Libraries Policy [Version 5.1.2600.1106, R1507]"...
    Checking: "Primitive: Cfgmgr32 [Version 5.1.2600.1106, R1507]"...
    Checking: "Class Installer - Other devices [Version 5.1.2600.1106, R1507]"...
    Checking: "FBA: PnP [Version 5.1.2600.1106, R1507]"...
    Checking: "HTML Rendering Engine [Version 5.1.2600.1106, R1507]"...
    Checking: "Msxml 3.1 [Version 5.1.2600.1106, R1507]"...
    Checking: "Windows Script Engines [Version 5.1.2600.1106, R1507]"...
    Checking: "HTML Help Engine [Version 5.1.2600.1106, R1507]"...
    Checking: "Accessibility Core [Version 5.1.2600, R620]"...
    Checking: "Primitive: Els [Version 5.1.2600.1106, R1507]"...
    Checking: "Workstation Service [Version 5.1.2600.1106, R1507]"...
    Checking: "Primitive: Netevent [Version 5.1.2600.1106, R1507]"...
    Checking: "Secure RPC over NTLM [Version 5.1.2600, R620]"...
    Checking: "Secure RPC over Negotiate [Version 5.1.2600, R620]"...
    Checking: "TAPI Terminal Manager [Version 5.1.2600, R620]"...
    Checking: "DirectShow Core [Version 5.1.2600.1106, R1507]"...
    Checking: "DirectShow Capture [Version 5.1.2600.1106, R1507]"...
    Checking: "TAPI Audio, Video and RTP Filters [Version 5.1.2600.1106, R1507]"...
    Checking: "SDP Blob Parser [Version 5.1.2600, R620]"...
    Checking: "Primitive: Uniplat [Version 5.1.2600.1106, R1507]"...
    Checking: "TAPI COM Client [Version 5.1.2600, R620]"...
    Checking: "Class Install Library - Mdminst [Version 5.1.2600.1106, R1507]"...
    Checking: "Primitive: SysSetup [Version 5.1.2600.1106, R1507]"...
    Checking: "Primitive: Storprop.dll [Version 5.1.2600.1106, R1507]"...
    Checking: "Primitive: MMSYS [Version 5.1.2600, R620]"...
    Checking: "Core Networking [Version 5.1.2600.1106, R1507]"...
    Checking: "MSFS [Version 5.1.2600.1106, R1507]"...
    Checking: "Primitive: Sclgntfy [Version 5.1.2600.1106, R1507]"...
    Checking: "Muli-Protocol Router Service Messages Library [Version 5.1.2600.1106, R1507]"...
    Checking: "Primitive: CertCli [Version 5.1.2600.1106, R1507]"...
    Checking: "Time Service Core [Version 5.1.2600.1106, R1507]"...
    Checking: "Common Control Libraries Version 6  [1.0.10.0] [Version 5.1.2600.1106, R1507]"...
    Checking: "Primitive: Advpack [Version 5.1.2600.1106, R1507]"...
    Checking: "Internet Explorer [Version 5.1.2600.1106, R1507]"...
    Checking: "Primitive: Mlang [Version 5.1.2600.1106, R1507]"...
    Checking: "Primitive: Shdocvw [Version 5.1.2600.1106, R1507]"...
    Checking: "HTML Help (Shared files) [Version 5.1.2600.1106, R1507]"...
    Checking: "Primitive: Rdbss [Version 5.1.2600.1106, R1507]"...
    Checking: "SMB Redirector [Version 5.1.2600.1106, R1507]"...
    Checking: "FBA: Net Common [Version 5.1.2600.1106, R1507]"...
    Checking: "RPC Remote [Version 5.1.2600, R620]"...
    Checking: "Secure RPC over Kerberos [Version 5.1.2600, R620]"...
    Checking: "Video For Windows Core [Version 5.1.2600.1106, R1507]"...
    Checking: "DirectDraw [Version 5.1.2600.1106, R1507]"...
    Checking: "DirectSound [Version 5.1.2600, R620]"...
    Checking: "Analog TV [Version 5.1.2600.1106, R1507]"...
    Checking: "Kernel Streaming User Mode Support [Version 5.1.2600, R620]"...
    Checking: "Primitive: Sfcfiles [Version 5.1.2600.1106, R1507]"...
    Checking: "Primitive: Sfc [Version 5.1.2600.1106, R1507]"...
    Checking: "Primitive: Powrprof [Version 5.1.2600.1106, R1507]"...
    Checking: "Netmscli Inf [Version 5.1.2600, R620]"...
    Checking: "Primitive: Winrnr [Version 5.1.2600.1106, R1507]"...
    Checking: "Multiple UNC Provider [Version 5.1.2600.1106, R1507]"...
    Checking: "DNS Cache Support [Version 5.1.2600.1106, R1507]"...
    Checking: "Microsoft Line Services [Version 5.1.2600, R620]"...
    Checking: "Shell Namespace Extensions [Version 5.1.2600.1106, R1507]"...
    Checking: "Primitive: Browseui [Version 5.1.2600.1106, R1507]"...
    Checking: "Primitive: Browselc [Version 5.1.2600.1106, R1507]"...
    Checking: "Primitive: Cdfview [Version 5.1.2600.1106, R1507]"...
    Checking: "Base Support Binaries [Version 5.1.2600.1106, R1507]"...
    Checking: "Primitive: Sendmail [Version 5.1.2600.1106, R1507]"...
    Checking: "Primitive: Shdoclc [Version 5.1.2600.1106, R1507]"...
    Checking: "Microsoft Foundation Class Library (Legacy) [Version 5.1.2600, R620]"...
    Checking: "Compression and Expansion Tools [Version 5.1.2600, R620]"...
    Checking: "Protected Storage Service [Version 5.1.2600.1106, R1507]"...
    Checking: "Fonts: Fonts Arial [Version 5.1.2600.1106, R1507]"...
    Checking: "Fonts: Fonts verdana [Version 5.1.2600.1106, R1507]"...
    Checking: "Primitive: Comcat [Version 5.1.2600, R620]"...
    Checking: "Mapi32 Libraries [Version 5.1.2600, R620]"...
    Checking: "Fonts: Fonts webdings [Version 5.1.2600, R620]"...
    Checking: "CodePage: 28591 (ISO 8859-1 Latin I) [Version 5.1.2600, R620]"...
    Checking: "DirectDrawEx [Version 5.1.2600, R620]"...
    Checking: "Primitive: Icfgnt5 [Version 5.1.2600.1106, R1507]"...
    Checking: "Primitive: Fixmapi [Version 5.1.2600.1106, R1507]"...
    Checking: "Down-level Shell Compat [Version 5.1.2600.1106, R1507]"...
    Checking: "Primitive: Shmgrate [Version 5.1.2600.1106, R1507]"...
    Checking: "Fonts: Fonts wingdings [Version 5.1.2600, R620]"...
    Checking: "Administrator Account [Version 5.1.2600.1106, R1507]"...
    Checking: "MCI Support [Version 5.1.2600, R620]"...
    Checking: "DirectShow ASF/DMO [Version 5.1.2600, R620]"...
    Checking: "Primitive: Stream.sys [Version 5.1.2600.1106, R1507]"...
    Checking: "Explorer Application [Version 5.1.2600.1106, R1507]"...
    Checking: "Shell Namespace Registry Data [Version 5.1.2600, R620]"...
    Checking: "Primitive: Olesvr32 [Version 5.1.2600.1106, R1507]"...
    Checking: "Primitive: Olecli32 [Version 5.1.2600.1106, R1507]"...
    Checking: "Shell Group Conversion Registry Data [Version 5.1.2600, R620]"...
    Checking: "Windows XP Service Pack 1 Resource DLL [Version 5.1.2600.1106, R1507]"...
    Checking: "Shell Explorer Registry Data [Version 5.1.2600.1106, R1507]"...
    Checking: "Shell Explorer Registry Data (Pro) [Version 5.1.2600, R620]"...
    Checking: "User Interface Core [Version 5.1.2600.1106, R1507]"...
    Checking: "Shell Core Registry Data [Version 5.1.2600, R620]"...
    Checking: "Shell Legacy Registry Data [Version 5.1.2600, R620]"...
    Checking: "Primitive: Ntshrui [Version 5.1.2600.1106, R1507]"...
    Checking: "Format Common User Interface [Version 5.1.2600, R620]"...
    Checking: "GUI Based Format Common Libraries [Version 5.1.2600, R620]"...
    Checking: "NT Loader [Version 5.1.2600.1106, R1507]"...
    Checking: "FAT [Version 5.1.2600.1106, R1507]"...
    Checking: "NTFS [Version 5.1.2600.1106, R1507]"...
    Checking: "Minlogon [Version 5.1.2600.1106, R1507]"...
    Checking: "English Language Support [Version 5.1.2600.1106, R1507]"...
    Checking: "FAT Format [Version 5.1.2600, R620]"...
    Checking: "NTFS Format [Version 5.1.2600, R620]"...
    Checking: "Device Manager [Version 5.1.2600.1106, R1507]"...
    Checking: "Date/Time Control Panel [Version 5.1.2600.1106, R1507]"...
    Checking: "Add/Remove Programs Control Panel [Version 5.1.2600.1106, R1507]"...
    Checking: "Add Hardware Control Panel [Version 5.1.2600.1106, R1507]"...
    Checking: "Accessories/System Tools [Version 5.1.2600.1106, R1507]"...
    Checking: "Accessories/Communications Programs [Version 5.1.2600, R620]"...
    Checking: "Display Control Panel [Version 5.1.2600.1106, R1507]"...
    Checking: "Keyboard & Mouse Control Panel [Version 5.1.2600.1106, R1507]"...
    Checking: "Map Network Drives/Network Places Wizard [Version 5.1.2600.1106, R1507]"...
    Checking: "Network Setup Wizard [Version 5.1.2600, R620]"...
    Checking: "Power Meter Control Panel [Version 5.1.2600.1106, R1507]"...
    Checking: "Safely Remove Hardware Program [Version 5.1.2600.1106, R1507]"...
    Checking: "System Control Panel [Version 5.1.2600.1106, R1507]"...
    Checking: "Task Manager [Version 5.1.2600.1106, R1507]"...
    Checking: "Windows Picture and Fax Viewer [Version 5.1.2600.1106, R1507]"...
    Checking: "TCP/IP Utilities [Version 5.1.2600.1106, R1507]"...
    Checking: "DirectShow DVD [Version 5.1.2600.1106, R1507]"...
    Checking: "DirectShow MPEG2 [Version 5.1.2600.1106, R1507]"...
    Checking: "DVD Playback [Version 5.1.2600.1106, R1507]"...
    Checking: "CodePage: 1252  (ANSI - Latin I) [Version 5.1.2600, R620]"...
    Checking: "CodePage: 437   (OEM - United States) [Version 5.1.2600, R620]"...
    Checking: "Mount Manager [Version 5.1.2600.1106, R1507]"...
    Checking: "User Locale: English - Australia [Version 5.1.2600, R621]"...
    Checking: "User Locale: English - Belize [Version 5.1.2600, R621]"...
    Checking: "User Locale: English - Canada [Version 5.1.2600, R621]"...
    Checking: "User Locale: English - Carribbean [Version 5.1.2600, R621]"...
    Checking: "User Locale: English - Ireland [Version 5.1.2600, R621]"...
    Checking: "User Locale: English - Jamaica [Version 5.1.2600, R621]"...
    Checking: "User Locale: English - New Zealand [Version 5.1.2600, R621]"...
    Checking: "User Locale: English - Phillippines [Version 5.1.2600, R621]"...
    Checking: "User Locale: English - South Africa [Version 5.1.2600, R621]"...
    Checking: "User Locale: English - Trinidad [Version 5.1.2600, R621]"...
    Checking: "User Locale: English - United Kingdom [Version 5.1.2600, R621]"...
    Checking: "User Locale: English - United States [Version 5.1.2600, R621]"...
    Checking: "User Locale: English - Zimbabwe [Version 5.1.2600, R621]"...
    Checking: "Language: English (Australian) - 0c09 [Version 5.1.2600, R620]"...
    Checking: "Language: English (Belize) - 2809 [Version 5.1.2600, R620]"...
    Checking: "Language: English (Canadian) - 1009 [Version 5.1.2600, R620]"...
    Checking: "Language: English (Caribbean) - 2409 [Version 5.1.2600, R620]"...
    Checking: "Language: English (Irish) - 1809 [Version 5.1.2600, R620]"...
    Checking: "Language: English (Jamaica) - 2009 [Version 5.1.2600, R620]"...
    Checking: "Language: English (New Zealand) - 1409 [Version 5.1.2600, R620]"...
    Checking: "Language: English (Philippines) - 3409 [Version 5.1.2600, R620]"...
    Checking: "Language: English (Trinidad) - 2c09 [Version 5.1.2600, R620]"...
    Checking: "Language: English (United Kingdom) - 0809 [Version 5.1.2600, R620]"...
    Checking: "Language: English (United States) - 0409 [Version 5.1.2600, R620]"...
    Checking: "Language: English (Zimbabwe) - 3009 [Version 5.1.2600, R620]"...
    Checking: "English MUI Resource [Version 5.1.2600, R620]"...
    Checking: "Primitive: Ufat [Version 5.1.2600.1106, R1507]"...
    Checking: "Primitive: Untfs [Version 5.1.2600.1106, R1507]"...
    Checking: "Primitive: Devmgr [Version 5.1.2600.1106, R1507]"...
    Checking: "Shell Control Panel Registry Data [Version 5.1.2600, R620]"...
    Checking: "Shell Control Panel Registry Data (Pro) [Version 5.1.2600, R620]"...
    Checking: "Primitive: Duser [Version 5.1.2600.1106, R1507]"...
    Checking: "Credential Management User Interface [Version 5.1.2600.1106, R1507]"...
    Checking: "Primitive: nddeapi.dll [Version 5.1.2600.1106, R1507]"...
    Checking: "Shell Hyperterminal Registry Data [Version 5.1.2600, R620]"...
    Checking: "Webdav Client Redirector [Version 5.1.2600.1106, R1507]"...
    Checking: "Netshell [Version 5.1.2600.1106, R1507]"...
    Checking: "Dos Windows on Windows Support [Version 5.1.2600.1106, R1507]"...
    Checking: "GDI+ 1.0.0.0 [Version 5.1.2600.1106, R1507]"...
    Checking: "Primitive: Winstrm [Version 5.1.2600.1106, R1507]"...
    Checking: "Routing Table Library [Version 5.1.2600.1106, R1507]"...
    Checking: "CDFS [Version 5.1.2600.1106, R1507]"...
    Checking: "UDFS [Version 5.1.2600.1106, R1507]"...
    Checking: "Audio / Video Core [Version 5.1.2600.1106, R1507]"...
    Checking: "BDA MPE Filter [Version 5.1.2600, R620]"...
    Checking: "Acm Core Codecs [Version 5.1.2600.1106, R1507]"...
    Checking: "CodePage: 850   (OEM - Multilingual Latin I) [Version 5.1.2600, R620]"...
    Checking: "CodePage: 10000 (MAC - Roman) [Version 5.1.2600, R620]"...
    Checking: "NetDav Inf [Version 5.1.2600, R620]"...
    Checking: "Wireless Zero Configuration [Version 5.1.2600.1106, R1507]"...
    Checking: "Application Compatibility Core [Version 5.1.2600.1106, R1507]"...
    Checking: "File Sharing [Version 5.1.2600.1106, R1507]"...
    Checking: "Legacy COM Support Library (16 Bit) [Version 5.1.2600, R620]"...
    Checking: "CMD - Windows Command Processor [Version 5.1.2600, R620]"...
    Checking: "System Compatible Manifest [Version 5.1.2600, R620]"...
    Checking: "GDI+ Side By Side Manifest 1.0.0.0 [Version 5.1.2600.1106, R1507]"...
    Checking: "GDI+ Policy [Version 5.1.2600.1106, R1507]"...
    Checking: "Digital TV [Version 5.1.2600.1106, R1507]"...
    Checking: "NDIS User-Mode I/O Driver [Version 5.1.2600.1106, R1507]"...
    Checking: "Netwzc Inf [Version 5.1.2600, R620]"...
    Checking: "Direct3D [Version 5.1.2600.1106, R1507]"...
    Checking: "Primitive: Sfcos [Version 5.1.2600.1106, R1507]"...
    Checking: "Computer Browser Service [Version 5.1.2600.1106, R1507]"...
    Checking: "Client for Microsoft Networks [Version 5.1.2600.1106, R1507]"...
    Checking: "Netserv Inf [Version 5.1.2600, R620]"...
    Checking: "GDI+ 1.0.10.0 [Version 5.1.2600.1106, R1507]"...
    Checking: "Ndisuio Inf [Version 5.1.2600, R620]"...
    Checking: "Cryptographic Service Providers [Version 5.1.2600.1106, R1507]"...
    Checking: "Primitive: Clbcatq [Version 5.1.2600.1106, R1507]"...
    Checking: "Primitive: Comres [Version 5.1.2600.1106, R1507]"...
    Checking: "Primitive: Win32Spl [Version 5.1.2600.1106, R1507]"...
    Checking: "Primitive: Localspl [Version 5.1.2600.1106, R1507]"...
    Checking: "Primitive: Spoolss [Version 5.1.2600.1106, R1507]"...
    Checking: "Print Spooler [Version 5.1.2600.1106, R1507]"...
    Checking: "Netbios Driver [Version 5.1.2600.1106, R1507]"...
    Checking: "Netnb Inf [Version 5.1.2600, R620]"...
    Checking: "Task Manager shell [Version 5.1.2600.1106, R1507]"...
    CFDB: 7.50 secs, 667 reqs. LAB: 8.40 secs, 3275 reqs, 79% hits, 200 entries
    Check complete, elapsed time: 19.53 seconds
    h-90% s-90%. Stalled
    hardware: epia en 1.2eg | 1gb ddr2 | belkin BT & wifi | 40gb/30gb | M1-ATX | mcs case & gps
    software: centrafuse | win xp pro | destinator 6
    PICS/WORKLOG HERE
    MINLOGON/WINLOGON PROBLEM
    At MEDC, a customer asked why TD kept complaining about Winlogon and Minlogon conflicting when he would disable or delete Winlogon but the next time he runs “Check Dependency” Winlogon returns and causes a conflict.
    Right, that’s because there’s a feature component in the config that has a component dependency on Winlogon, if you want to force Minlogon just turn off “Autoresolve” in Target Designer and satisfy all other dependencies other than that one. If you’re not concerned about footprint and some superfluous features winding up in the runtime, another trick is to leave winlogon in the config, remove Minlogon, satisfy all other dependencies. But before you build, disable Winlogon and manually add Minlogon back to the config; don't run check dep again, just build it.
    from: http://blogs.msdn.com/embedded/archi...16/417659.aspx
    STALLED. i'll try it out next time. need sleep. 8+ hours trying to do this is killing me.
    for some reason i cant get mdac 2.8, .net 1.1, and dx9.0c to install. anyone wanna help out?
    i redid the target component to the design template: information, add a few other stuff but to no avail. i might try kiosk/gaming.
    i really need other people's input on this. or better yet, someone make a new template/component compilation for this.
    i went through 15 images (6 .slx with different variants), close... but no cheese.
    PICS/WORKLOG HERE
