CF card problems
  • CF card problems
    I have a new transcend 4GB CF card. It says it supports both removable disk and fixed disk mode. When I try and install XP to it, it always says "could not find hard drive". I can see it as a hard drive in the bios. What am I doing wrong here?
    Also, I installed xp to a regular hard drive on the same computer then tried to transfer over all the files to the CF and tried booting it that way. Didn't work, said something about insert the right boot device.
    Please help! I'm not sure what else I can do. I found a program sandisk made to convert removable CF to fixed disk mode. It has a .com extension and I don't know how to use. I don't know why I would need to do that if my card supports fixed disk mode already. HELP!
    2004 Nissan 350z Daytona Blue
    2x 10" IDMax D4
    1250.1 kicker amp
    crappy dell carputer
    you should not install directly to the CF card. check the site in my signature for installation steps. if your card supports fixed disk mode you should check with Transcend how to enable it. the SanDisk utility will most likely not work since it's made for SanDisk cards (I don't believe SanDisk and Transcend use the same CF controllers).
    EWF, HORM, MinLogon on XP.
    Zotac ION Atom N330, 2GB low-profile RAM, M3-ATX
    Win Embedded Std 2011 RC
    OCZ Vertex Turbo 30GB SSD
    Lilliput 629 Transflective, WRX Screen Mount
    BlueSoleil BT, i-Blue GM-2 GPS, DirectedHD Radio, Andrea Mic
    VoomPC 2
